Tire size?
Old Dec 1, 2006 | 12:34 PM
zenmoused's Avatar
the stig is my hero
Tire size?
I need to buy tires like yesterday, and I've decided on Kumho Ecsta SPT's per everyone's recommendations. One thing I'm a little confused about is which size to get. A lot of people are getting 245/40/18 rather than the recommended 45. Is there an advantage to this? Any disadvantages?
Old Dec 1, 2006 | 01:11 PM
LionZoo's Avatar
road warrior
45 series is for the stock 225 width. If you want the 245 width (which will fit on the OEM 8 inch wide rims), 40 series is what you want.
Old Dec 1, 2006 | 01:12 PM
The 40 series is closer to OEM circumferance, and will effect the speedometer only a bit.
The 45 series are bigger around...more error
Old Dec 1, 2006 | 02:05 PM
zenmoused's Avatar
the stig is my hero
oops i meant 225/40/18 and 225/45/18. Is there any way to adjust the speedometer?
Old Dec 1, 2006 | 02:13 PM
zenmoused's Avatar
the stig is my hero
Wait, would it be a mistake to order 225/40/18? Should I just go for the 225/45/18 instead?
Old Dec 1, 2006 | 02:18 PM
go with 245 / 40 / 18. Very little change to your odometer (bout .5 mph) I believe. It would be quite difficult to adjust your speedo.
Old Dec 1, 2006 | 02:20 PM
zenmoused's Avatar
the stig is my hero
thanks for your help man. I'm clueless when it comes to tires.
Old Dec 1, 2006 | 02:32 PM
no problem, so was I until recently.
Old Dec 1, 2006 | 02:39 PM
ZoomZoomH's Avatar
Mulligan User
*very* quick overview on how to read tire dimension #'s:
let's use 245/40/18 as example
245 - 245mm of tire TREAD WIDTH
40 - thickness of the SIDEWALL as a percentage to the tread width (in this case the sidewall is 40% of 245mm)
18 - fits 18" wheels
Old Dec 1, 2006 | 02:44 PM
zenmoused's Avatar
the stig is my hero
Thanks guys. I ended up getting 245/40/18's. The 225/40's would have been like a 5% change in speedo and odometer, and I def wanted to switch to a 40.
Old Dec 1, 2006 | 04:26 PM
The sidewalls on the 245/40 are almost exactly the same as the 225/45...so they will look the same in profile...but the extra 3/4 inch width will be nice...both for looks..and traction
yurcivicsux
192
Sep 12, 2017 10:54 PM
hppy4u
Gulf For Sale/Wanted
9
Dec 3, 2015 09:11 PM
CMRine04
Sep 17, 2015 10:04 AM
