Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
Put the OEM trunk spoiler on today!
Old Nov 19, 2006 | 11:21 PM
skwidd's Avatar
ZEE-non
It looks great, very easy to install. I'll see when I can get pics.
One question I have is why do the instructions say to drill 10mm holes for the screws? It looked like 8mm holes would work fine. I mean, everything lined up, so why did I need to drill 10mm holes???
Old Nov 20, 2006 | 02:58 AM
BigOLundh's Avatar
#1 Legend
10mm hole and then a washer for the screw. Also then you can allign it incase you were slightly off when drilling.
Old Nov 20, 2006 | 08:25 AM
skwidd's Avatar
ZEE-non
OK. I was wondering if it had to do with tolerances. I actually didn't drill them out to 10mm because the 8mm holes lined up fine and I was able to tighten it down without needing to bore the holes out bigger.
Thanks.
BigMikeATL
May 26, 2016 12:31 AM
RZ1
Aug 24, 2015 01:04 PM
cschoeps
Aug 6, 2015 12:44 PM
arjunmshah
Aug 6, 2015 10:56 AM
Jazzmeson
Jul 31, 2015 01:48 AM
