Canzoomer Issues
Old Nov 15, 2006 | 09:57 PM
RotaryBred's Avatar
Canzoomer Issues
I've been having some issues with my Canzoomer Stage 2 and E-manage. It seems that no matter what I do, my software keeps saying "connection problem, check your cables". i've tried switching versions of emanage and tried it on a newer laptop with USB 2.0, and I managed to get it to say "this unit is not compatable with this version of emanage". I pressed ok, and tried to import the settings from my unit. It seemed to be working, but when it was done importing, nothing came up on my screen. I've been bugging Maurice everyday so I figured I'd ask someone else.... So here are some questions..
What the hell is goin on?
Is emanage only compatable with USB 2.0?
Are there some versions of emanage that do not work with CZ?
Oh and here's something to ponder... it will show real time data... but nothing will import/export
Old Nov 15, 2006 | 10:06 PM
09Factor's Avatar
Original Turbo 'd Auto !!
which ver. is cz/emanage?
Old Nov 15, 2006 | 10:07 PM
mysql101's Avatar
are you using the special usb connector, or are you using a generic usb cord?
Old Nov 15, 2006 | 11:13 PM
RotaryBred's Avatar
so far i've tried emanage v1.1 and 1.2
ive tried updating to 1.49 but all of the files seem to be corrupt when i try installing them
not sure what version the CZ is... date on it is 10/04
i have the special USB cable
Old Nov 16, 2006 | 01:12 AM
j_s2000's Avatar
i have exactly the same problem! i bought and exchanged 12 usb adapters already! non-worked!
Old Nov 16, 2006 | 01:38 AM
RotaryBred's Avatar
i finally got somewhere... i had to use the newest version 1.49 on my old laptop USB 1.0 (go figure)... but i'm not in the clear yet... it seems to be doing everything its supposed to do as far as communication goes, but when i import the maps, nothing shows up therefore i have nothing to modify. it says "corrosponding" but when its done i get nothing. wtf i'm so lost with this stupid thing
j s2000, have you tried using a different laptop? after switching between them about 50 times, i think the unit got fed up with me and cut me some slack
Old Nov 16, 2006 | 01:48 AM
j_s2000's Avatar
i have tried a different laptop and same error occurred. i am basically running the CZ untuned at this point, however, my AFR is 12.1 which isnt really that bad. i am looking to maximize the gain from this unit. im searching for ppl on this forum who knew how to tune this and also shops in socal.
Old Nov 16, 2006 | 02:16 AM
RotaryBred's Avatar
thats about where my AFR was before i put my intake on... now i run with the CZ off because with the intake it puts my AFR up in the 16 range! so until i tune it i can't even use it
Old Nov 16, 2006 | 01:28 PM
r0tor's Avatar
did you install the drivers required for the USB cable?
JimmyBlack
273
Feb 10, 2020 10:23 PM
LB2739
Jul 9, 2019 02:25 AM
Irvinb16
Sep 11, 2015 10:27 PM
tgaffner
Sep 7, 2015 08:49 PM
