Agency Power Brakelines
Old Nov 12, 2006 | 08:01 PM
LionZoo's Avatar
road warrior
Has anyone tried out the aforementioned lines? It seems that they have a cover over the braided steel to protect from dust and that they're DOT legal. Any feedback or opinion would be welcomed.
Old Nov 12, 2006 | 08:20 PM
AlexCisneros's Avatar
work great for me...
so does their clutch line
Old Nov 12, 2006 | 09:43 PM
Im_DANomite's Avatar
I love GOOOLD
ditto. install was a piece of cake. quality made items. you don't really feel a noticeable difference since the stock lines won't be completely stretched out.
Old Nov 12, 2006 | 09:53 PM
Good only for looks. Gives a stiffer feeling but doesn't help performance.
Braided lines have been known to get pinched on the track.
Old Nov 12, 2006 | 10:21 PM
LionZoo's Avatar
road warrior
Pinched by what? It looks like the Agency Power lines (unlike the Goodridge lines) use the same mid-line attachment spot as the OEM rubber lines to prevent the danger of having one long line hanging in the breeze.
I understand it doesn't give a performance benefit, but I love rock hard brake pedals.
Old Nov 12, 2006 | 10:24 PM
redcivic's Avatar
Guns, God, and Country
Pinched? I don't believe that. I have never seen or heard of that.
Old Nov 12, 2006 | 10:26 PM
I love GOOOLD
i had mine on the track...no problems. the rock hard pedal you feel won't be that noticeable.
Old Nov 12, 2006 | 10:57 PM
LionZoo's Avatar
road warrior
True, but I'm looking for fade resistance that are superior to that needed on tracks for 15 or 30 minute lapping sessions. Any extra pedal hardness would be great too.
Old Nov 13, 2006 | 01:21 AM
I have the Goodrich lines, there's nothing wrong with the way they do the mid-way mounting point
Fade resistance has little to do with the flexible brake line
Old Nov 13, 2006 | 01:31 AM
LionZoo's Avatar
road warrior
In terms of actual brake bite that is true, however the OEM rubber lines will expand when the fluid is hot causing your pedal to be a bit softer.
Old Nov 13, 2006 | 10:10 AM
the pedal will travel a miniscule amount further and you have to push a small amount harder to compensate, it still has nothing to do with fade resistance, fade is losing braking power regardless of how hard you push on the pedal
Old Nov 13, 2006 | 11:38 AM
LionZoo's Avatar
road warrior
Team, you're thinking of one type of fade; that of boiling brake fluid which reduces the actual amount of braking you have. I'm talking about another type of that, this type does not decrease your braking power, but does affect the feel of the brake pedal (causing problems in pedal modulation). I think this is termed green fade, but it's been a long time since I last read Tune to Win.
Old Nov 14, 2006 | 06:57 PM
Pinched by going over curb or off track, Hitting a rock or a rock coming up and hitting the line.
Not very common, but it has happened.
Discussion with Tri point racing agrees this can happen.
Old Nov 15, 2006 | 10:50 PM
That book is how old??? OE brake lines were a lot different then ... unless you're in a real competition scenario don't bother. Plenty of people are tracking with their OE flex brake hoses without any issues. IMO you're making a mountain out of a molehill. No book ever replaced practical experience ...
Old Nov 15, 2006 | 10:58 PM
I love GOOOLD
^^ word. it's not really that big of a difference. fade has nothing to do with lines. lines don't help brake harder either, they're only for feel. i'd be more concerned with brake fluid, rotors, and pads.
Old Nov 16, 2006 | 01:46 PM
KYRX8's Avatar
Agreed. I used the Stoptech Stage 2 upgrade on mine. Came with Slotted rotors, pads, lines, and Motul fluid.
Costs about 650 bucks for the whole pacakge, but thats cheaper than buying it all seperately.
Shankapotamus3
Mar 14, 2021 03:53 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
D13
Oct 1, 2015 07:55 AM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
