SpeedB
11-12-2006, 04:22 PM
i see alot on here about the clear side corner markers, i was wondering if any one has ever seen smoked ones before and where to get them
View Full Version : smoked clear corners SpeedB 11-12-2006, 04:22 PM i see alot on here about the clear side corner markers, i was wondering if any one has ever seen smoked ones before and where to get them j67345 11-12-2006, 07:16 PM I think X-PED was selling a set a couple weeks ago...he had some pics. You might shoot him a PM Freddie 11-12-2006, 07:19 PM I don't know if smoking them is a good idea. Would like to see pictures or at least a description from someone who has tried it. CTrx8 11-12-2006, 07:52 PM i think those were smoked ambers, not smoked clears. Freddie 11-12-2006, 07:55 PM What color car ? CTrx8 11-12-2006, 07:59 PM wasn't shown on a car. http://www.rx8club.com/showthread.php?t=102656 4 years to Supercharge 11-12-2006, 08:04 PM That is correct CTrx8. The other thing that has been done is applying a translucent vinyl that can be seen through (done on the amber corners also). I saw it on a sunlight silver 8 and thought it looked real good also. Here are some clear corners that were smoked but the light can still be seen when they are on. Oh and one is red stock corner markers. Freddie 11-12-2006, 08:05 PM Smoked might be OK for me, but definitely not the amber. My car is Winning Blue. NgoRX8 11-12-2006, 09:46 PM i like smoke. N rider89 11-12-2006, 09:53 PM smoke :smoker: rglbegl 11-13-2006, 10:50 AM This is why I leave mine amber. You can get away with white reflective with an amber bulb, but that is about it here in Cali 25100. (a) Except as provided in subdivisions (b) and (d), every vehicle 80 inches or more in overall width shall be equipped during darkness as follows: (1) At least one amber clearance lamp on each side mounted on a forward-facing portion of the vehicle and visible from the front and at least one red clearance lamp on each side mounted on a rearward-facing portion of the vehicle and visible from the rear. (2) At least one amber side-marker lamp on each side near the front and at least one red side-marker lamp on each side near the rear. zenmoused 11-13-2006, 07:46 PM Amber doesn't look half-bad with white. Clear corners look a bit better though :) MadDashRX8 11-13-2006, 08:47 PM Here's my OEM corners with vinyl overlay. I had some scrap left over after "tinting" my rear side windows for the kids. They are still reflective at night, and I did the turn signal mod, so they are visible when they need to be. phat8 11-14-2006, 02:45 AM sun eventually eats away at the tints and becomes brittle if on the out side. this you could think is ok, cos u can just peel it off and re apply. but it leaves the glue impossible to get off. and we know what any kind of thinners etc... does to plastic. dont use tints, i learned the hard way on another car. Razz1 11-14-2006, 02:31 PM 3M adhesive remover or rubbing alcohol will remove the glue. Brake cleaner? Works on interior plastic, so why not the outside? speeddemon32 11-14-2006, 02:44 PM here are some corners that were at the San Berdo meet on Saturday. :) http://www.rx8club.com/attachment.php?attachmentid=89308 Razz1 11-14-2006, 02:47 PM Did Kieth change his from Red to Black corners on the Black 8 ? Jedi54 11-14-2006, 03:02 PM nope, Keith's are the stock amber ones. He doesn't like the lines of the clear corners. 4 years to Supercharge 11-14-2006, 05:09 PM 3M adhesive remover or rubbing alcohol will remove the glue. Brake cleaner? Works on interior plastic, so why not the outside? Brake cleaner can weaken plastic and make it brittle. :nono: |
