just need quick help (spark plugs w/ turbo)
Old Nov 9, 2006 | 07:48 AM
Acclaim99's Avatar
Just wondering what set of plugs for my turbo 8
tia
and i did search
is the bur9eq / bur7eq
what i should go with?
Old Nov 9, 2006 | 07:57 AM
mysql101's Avatar
NGK-5255 / BUR9EQP
http://rotaryinsider.com/rx8-9.html
Old Nov 9, 2006 | 08:07 AM
Acclaim99's Avatar
ok..
not recommended to get the bur7eqp for leading then ?
Old Nov 9, 2006 | 09:15 AM
mysql101's Avatar
shouldn't be a problem to use 5255 for all 4.
Old Nov 9, 2006 | 02:49 PM
Acclaim99's Avatar
ok, well, got 3 done... cant get to the other one, so it will have to wait :-\
Old Feb 6, 2007 | 10:05 PM
LiL BenNy's Avatar
Bubblicious? DEF.
http://www.amazon.com/NGK-5255-Plati.../dp/B000COX5RE
are these the right ones?
Old Feb 6, 2007 | 10:09 PM
mysql101's Avatar
yes, but the photo depicted is not accurate. I've bought them directly from summit before.
Old Feb 6, 2007 | 10:30 PM
Fanman's Avatar
I used the RE8A-L, these are 1 heat range colder than the stock plugs, yet ran just as well. I tried the Denso Iridiums (also one heat range colder than stock) but noticed a bit more vibration, wasn't as smooth as when I had the NGK's.
JimmyBlack
273
Feb 10, 2020 10:23 PM
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
rotorocks
47
May 11, 2016 03:23 PM
Brokegang
Jan 3, 2016 12:45 PM
