In-tank fuel pump upgrades?
Old Nov 8, 2006 | 12:19 PM
demon's Avatar
Question In-tank fuel pump upgrades?
Does anyone know of any in-tank fuel pump upgrades for the RX8? I'd rather not use an external pump if I don't have to!
Old Nov 8, 2006 | 12:21 PM
maxxdamigz's Avatar
Baro Rex
Mazsport. Done.
Old Nov 8, 2006 | 06:19 PM
Ciao's Avatar
Speak to Manuel from PR.He did this a year ago
Ciao
Dave
Old Nov 8, 2006 | 09:26 PM
SpyderX,Inc.'s Avatar
FedExman04
hey dude, i replaced my stock pump with a walbro. it will fit just fine, well maybe once u put the rubber gasket circle thing back on, then it be kinda tight. but thats ok cuz extra seal is better. just open the pump casing and everythin should be simple. also u have to splice wires and make sure u use heat shrinkin tube to cover it all up. anything else just ask me. bye for now
Old Nov 9, 2006 | 07:04 AM
Ciao's Avatar
Part numbers and Pix please I think a few people would love to know
Maybe stick it under the DIY Section
Is it an afternoon job?Or a whole day-er
Ciao
Dave
Old Nov 9, 2006 | 12:07 PM
demon's Avatar
Would definitely like to know which pump you ended up using; I've converted my system to return-based with external FPR so need to get rid of the stock pump asap! Did you use the FD walbro drop-in?
Old Nov 9, 2006 | 12:25 PM
demon's Avatar
By the way, is the only way to get to the pump using the mazda tool to remove the big plastic circular casing from the tank?
Old Nov 9, 2006 | 12:32 PM
MazsportScott's Avatar
Mazsport.net
The Mazsport pump is actually a plug and play kit that uses the factory connectors and lines. The system utilizes a rising rate regulator and converts the factory system to a return system. The pump is a proven reliable unit and will support more than 400rwhp in rotary applications. Because we have done most of the work it requires about 1.5-2 hours for the complete install, we have them in stock and ready to ship! On a side note, Mazsport does NOT use Walbro pumps.
Old Nov 9, 2006 | 12:59 PM
demon's Avatar
Thanks Scott, but I actually need a pump with no regulator built in; sounds like a great kit though.
Old Nov 9, 2006 | 01:02 PM
Mazsport.net
That could be arranged as well! If I can help call me at 1-800-538-9989,Scott
Old Nov 9, 2006 | 01:23 PM
demon's Avatar
Just called you and left a message!
Old Nov 9, 2006 | 01:46 PM
slavearm's Avatar
Boost Junkie
I will be sure to let you know Scott. LOL. Man boost is worse than crack.
Old Nov 9, 2006 | 07:41 PM
FedExman04
do u have that fuel pump removal tool? and where did u get it
Old Nov 9, 2006 | 07:43 PM
FedExman04
Ciao
Dave
well for me its a 10 min job to remove it but for a first timer, it may take half a day to do it. make sure u remove it carefully and disconnect everything
Old Nov 9, 2006 | 07:45 PM
FedExman04
yea, i just replaced stock pump wit walbro and put it back in the staock pump casin. how did u make urs a return system? could i just stick a nipple on top of my fuel pump system and add a really long fuel line to the front?
Old Nov 10, 2006 | 10:43 PM
Ciao's Avatar
Which Walbro unit was it ?
And are you getting much more fuel pressure/Supply ?
Old Nov 10, 2006 | 10:47 PM
FedExman04
i justed typed in supra fuel pump and walbro poped up on ebay so i got it for my car. and i think my car is runnin richer but not sure if the walbro had anything to do wit it.
Old Nov 10, 2006 | 11:51 PM
Ciao's Avatar
Is it the Walbro GSS-342 Pump ? or the GSS 341 ?.Or something else?
Old Nov 11, 2006 | 05:05 AM
FedExman04
i didnt kno there were different kind of walbro......hmmm i just watever came up on ebay. sorry if i wasnt much help
Old Nov 11, 2006 | 07:28 PM
olddragger's Avatar
i heard that Walbro pumps may not be very dependable. From reliable source. But that is only an opinion. I wish more choices where out there. Mazsports kit looks real good and I may end up with that.
olddragger
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
DVerdeyen
Sep 29, 2015 10:31 PM
Shumster
Sep 10, 2015 11:05 PM
