Only 2 new tires needed
Old Nov 7, 2006 | 08:18 PM
kevsRX8's Avatar
My stock tires are worn out on the back. (21000 miles) The front look like new. I cannot explain it but I need 2 new tires. I am not keen on dropping the cash to replace the rear with oem tires. Are there any opinions on replacing only the rear? Any suggestions on what to replace them with? I would like to spend less than $150 each.
Old Nov 7, 2006 | 11:41 PM
ac3mastuh's Avatar
Got Ings?
kumho ecsta is the way to go
inexpensive, good quality, get it in 225/45/18 to save a bit of cash
Old Nov 8, 2006 | 05:12 AM
Straight8's Avatar
^^^Ditto
Old Nov 8, 2006 | 09:38 AM
sonicblue6's Avatar
Check your e-mail! This is almost crazy how perfect a solution I have for you.....
Old Nov 9, 2006 | 06:30 PM
MadDashRX8's Avatar
Resu Deretsiger
I rotate mine. I never get stuck in your situation. Buy 4 at a time.
Old Nov 9, 2006 | 08:57 PM
kevsRX8's Avatar
I didn't rotate because I had to patch one of the rear tires. I didn't feel comfortable putting a patched tire on the front. If the rear blows you can still have some control. If the front blows you are screwed.
Thanks for the comment though. I didn't learn proper tire maintenance in my MBA classes.
Old Nov 9, 2006 | 10:40 PM
jd pilot's Avatar
I've got 4 oem tires with about 8K miles on them. All the miles were pampered...i.e. normal driving, no racing, burn outs, ect. and garaged the entire time. PM me if you are interested in 2 or all 4
Old Nov 11, 2006 | 03:02 PM
MadDashRX8's Avatar
Resu Deretsiger
Maybe proper maintenance is included in the PhD courses?
I don't think I'd put a patched tire on the front, either.
Old Nov 11, 2006 | 04:07 PM
ken-x8's Avatar
It's actually the other way around. Blow a rear tire and the back won't track behind the front: the car may spin out or swap ends. Blow a front tire and you can compensate for the lopsidedness with steering. Won't handle well, but it won't suddenly swap ends.
If a tire is correctly patched and balanced, it will be OK on either end.
Ken
Duren1
Mountain For Sale/Wanted
Jan 11, 2017 09:07 AM
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
Modified Dave
Aug 20, 2015 07:38 PM
