aftermarket header
Old Nov 3, 2006 | 07:05 PM
blueballz's Avatar
aftermarket header
Would an aftermarket OBX header add significant hp and torque and would the sst or heated oxygen sensor be effected by this swap??? ?
Old Nov 3, 2006 | 07:16 PM
rotarygod's Avatar
No and no.
lazi's Avatar
drivelinestore.com
please don't get obx.
Old Nov 3, 2006 | 07:30 PM
blueballz's Avatar
what would you suggets as a modification to increase torque???
Old Nov 3, 2006 | 07:33 PM
unreal89's Avatar
I don't mind pistons
a v8
Old Nov 3, 2006 | 07:37 PM
TitaniumRenesis's Avatar
I am McLovin
are there any aftermarket headers worth getting??? Thanks.
Old Nov 3, 2006 | 07:38 PM
O'Renesis's Avatar
Thumbs down OBX Header
I have the OBX header and can only say that it is very poorly designed and also is not a good fit for the Renesis engine. The exhaust port size on the OBX are not a match to the Renesis exhaust ports. e.g. The two outside ports on the Renesis engine are considerably wider than the centre port but this is not the case with the OBX header.
The OBX header ports are all the same size i.e same as the centre port. The OEM exhaust header port dimensions are: Centre Port= 53mm high x 24mm wide and the two outside ports are 53mm high x 37mm wide (approx).
Added to the above the OBX header has not got provision for the secondary air pump to function as it was originally designed.
I guess you get what you pay for in this instance.
I cant say if any aftermarket header can give more torque or horspower?
rotarygod's Avatar
In all seriousness mods don't do much on the Renesis. You'll spend a lot and get fairly little. The best way to increase torque is to go forced induction such as a turbo kit.
Old Nov 4, 2006 | 10:49 AM
Skiptomylue's Avatar
but wouldnt an aftermarket header be benificial with a Fi kit? s/c or turbo? it may not do much on an NA engine? but wouldnt it add significant Gains on a FI'ed Car???
Old Nov 4, 2006 | 11:58 AM
alnielsen's Avatar
A well designed one would, but so far no one has come up with a good design. A well designed header would be beneficial to both NA and FI. But, only if the OEM header was of an inefficient design. The only thing you get with the OBX header, from what I've heard, is the loss of a few pounds.
Old Nov 4, 2006 | 04:57 PM
Bart!'s Avatar
RAWR!@#
What aftermarket header other than the one that comes with the Greddy kit will fit a t618z? I'd like a stainless steal exhaust manifold/downpipe wrapped with a heatshield rather than my cast iron Greddy one but I'd have to get one custom made.
Like rotarygod said, FI is the only way you can get real torque numbers. I hit 245tq at 10psi on my last dyno run.
Old Nov 4, 2006 | 08:51 PM
BoosTED's Avatar
Going with a bigger turbo will require it to be in the engine bay because of the location limitations where the Greddy turbo is.
Old Nov 4, 2006 | 09:50 PM
Bart!'s Avatar
RAWR!@#
That was a hypothetical question.
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Brokegang
Jan 3, 2016 12:45 PM
jorx7
Sep 29, 2015 04:54 AM
