help with wiring boost gauge..flickering?
Old Oct 29, 2006 | 10:17 PM
RX-XSIV's Avatar
turbo'd w/ excellence
currently running greddy turbo.. the ATF gauge and the boost gauge are currently running on the power drawn from the cigarette lighter..i think i might be losing power because the boost gauge is starting to flicker..very slightly though.. could it be the wire? .. anyone running FI currently if you could help me out as to what the problem might be exactly and what the solutions are for the proper gauge set up would be great as in terms of where would be the best place to run the wire for the boost gauge.. thanks =]
Old Oct 30, 2006 | 12:07 PM
RX-XSIV's Avatar
Old Oct 30, 2006 | 12:15 PM
slavearm's Avatar
Boost Junkie
Re-Check your wiring. I ran my boost controller and guages off of the cig line, but I ran the ground to Chassis.
Old Oct 30, 2006 | 12:50 PM
rotorocks's Avatar
RotoRocks Powered
Check and make sure you got goot connection on the contacts. And that no wire are pinched/broke when you tightened the panels back on.
JimmyBlack
273
Feb 10, 2020 10:23 PM
05rx8mazda
Nov 28, 2015 09:42 AM
JantzenRX-8
Oct 4, 2015 11:30 PM
jer2911
Sep 29, 2015 06:37 PM
