tmak26b
10-28-2006, 09:54 PM
After a four years of no rotary engine, I finally found a 2004 used automatic RX-8 for my girlfriend. The car is a winning blue with custom blue leather interior. It has all the stupid packages along with the navigation system. The car is in excellent condition with 36K miles (built 6/03). Anyway I know about the oil and fuel burning issue with the rotary since I had a 86 and 90 RX-7 before. I will be sure to tell her to check it often. I do have a few question that I hope you guys can answer.
#1 What type of oil should I use? How much should I put in once I drain the oil?
#2 What is the recommended change interval for spark plugs and coils? I assume 30K for the plugs from what I heard. What about the coils and plugs? I have heard of problems with them.
#3 What is the deal with the dipstick, is it possible to get a modify part that is longer? I really don't want my gf to get dirty just to check the stupid oil. I will be sure to keep two quarts of oil, gloves and a funnel in the car.
#4 Is the oil pressure gauge in the car functional or is it stupid?
#5 How do you program the TPMS sensors assume I go to different wheels? How does that work?
#6 What type of ATF does it use?
#7 Heated seats, how well does it work? The one on the smurf isnt that great.
#8 Is the warranty on the powertrain up to 5 yr 60K now?
#9 What do you guys recommend for extended warranty?
What other things should I look for in this car? The car seems to be in great condition, I just want to do all the maintanence parts so she can keep it running longer.
