Warning light?? what is this!!??
Old Oct 27, 2006 | 12:44 AM
rock-rock's Avatar
Spinners under the hood
Hi all, I just bought my beauty today 10-26-06, and I noticed a light come on in the gauges that keeps blinking!!, see picture. I dont know what this means?? also any tips as far as maintanence for the 8 in general would be welcome too, thank you.
[IMG][/IMG]
Old Oct 27, 2006 | 12:53 AM
Mazdaspeed RX8 ver2's Avatar
[IMG][/IMG]
thats the tmps (tire monitoring pressure system). It means that one of the four tires have low air. recommendations would be to check the tire pressure on all 4 tires and if it is at a low pressure, fill it up with air and then take it somewhere to find if the tire has a nail or something stuck in it or has a hole that would cause air to leak.
Old Oct 27, 2006 | 12:59 AM
rock-rock's Avatar
Omg, thank you so much for the quick response, it is late here and I would have been worried all the way to work tomorrow morning, I will check the pressure, thanks again!
Old Oct 27, 2006 | 01:03 AM
no problem! had the tmps go off on me a few times, saved me those few times as well. if the car starts to beep with the tmps light on, that means its getting dangerously low on air and that you should drive slow or pull over. but yeah, no problem, check your tire pressure!
Old Oct 27, 2006 | 04:30 AM
TheBri's Avatar
Spastic Monkey
I'm not trying to be a complete smartass but:
READ THE MANUAL THAT CAME WITH YOUR CAR.
It's not difficult to do. There is an entire section on what all those lights mean and in many cases what to do if one comes on.
Old Oct 27, 2006 | 06:19 AM
CTrx8's Avatar
space for rent
^agreed. i'm not sure if the temp has dropped in CA but that could be it as well. aside from reading the manual, you should also be checking your tire pressure often. this could be a case of a nail or just winter coming along and the air in the tires contracting.
Old Oct 27, 2006 | 02:35 PM
WikkedOne's Avatar
Deals on wheels
This topic is well covered I think.. but i would like to mention that that light will come on if your tires are overinflated as well. I aired up my tires using a bad gauge one time, and after driving for a few mins that light came on.. I couldn't figure out what it was. It was too much pressure after the tires had warmed up.. go figure..
Old Oct 27, 2006 | 04:00 PM
maxxdamigz's Avatar
Baro Rex
I was confused the first time I saw it myself as the picture could be confused with all sorts of traction related warnings. However, it only took me 2 min to look it up in the manual. Luckily, it was only the 30 degree drop in temperature and not a punctured tire. The warning is also self resetting when you get it fixed.
Old Oct 27, 2006 | 08:47 PM
Tigster's Avatar
RX8 ADDICTED!!!
If you see a little red man with a line through it you need to buckle your seat belt. If you se a yellow dot under the gas gauge you need to check the blinker fluid.
Old Oct 28, 2006 | 01:08 AM
[IMG][/IMG]
wow,
you can take a pic, and post it... but you cant read the fing manual? the oil change is going to kill you...
btw, welcome..
read, search, learn.
Old Oct 28, 2006 | 10:05 AM
Paul_in_DC's Avatar
Rotary Public
I thought this meant "Hey Lady! Your slip is showing!"
Old Oct 28, 2006 | 10:57 AM
lone_wolf025's Avatar
Future Rotary User
I dunno if I'd want to see THAT slip
Old Oct 28, 2006 | 11:48 AM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Originally Posted by swoope
wow,
btw, welcome..
Old Oct 28, 2006 | 12:38 PM
army_rx8's Avatar
X-Sapper
LOL ahhh different stroks for different folks
Old Oct 28, 2006 | 05:59 PM
It means you need to lose some weight. The warning light says that your as* is too fat to fit in the seat.
Old Oct 29, 2006 | 10:46 PM
Guino's Avatar
Road Runner Developer
The manual fails to mention things like the parking break light coming on when low on break fluid or when break pads are worn -- had it said so, I would not have taken my car to the dealer (specially after checking that the break fluid was above minimal limit and break pads were good).. so yeah, read the manual, but be skeptical about it too.
cliffkemp
Dec 24, 2024 10:48 AM
xAgyex
Sep 28, 2015 08:54 AM
drlubell
Sep 26, 2015 11:58 PM
Evan Gray
Sep 26, 2015 12:30 PM
