aftermarket wheel/tire size
Old Oct 21, 2006 | 09:37 PM
6speed's Avatar
College
Hey im currently debating buying new rims/tires for my 06 phantom blue. Anyone know how wide i can go as far as a 17 inch rim? i just think the 18's are too rough for the size of the car (respectively). I'm hoping 9 inch in the front and maybe 9.5 or 10 in the rear (wide). any precautions for mounting this size or suggestions on the tire size? thanks for any and all help. Oh ya, is there any way i can remove the ask.com links on certain words?
Old Oct 22, 2006 | 01:48 PM
dtorre's Avatar
Ultimate ****** Goderator
wow 10 inches on the 8 with 17 inch rims....?? lol....I think that if you do go 17's try and keep them down to 225's .....however lower the car as well because its gonna look stupid as heck without some form of aftermarket suspension to cover up that extra wheel well
Old Oct 22, 2006 | 08:30 PM
6speed's Avatar
College
17 inch wheel, bigger tire sidewall, i said the 8 is a little rough, im not gonna shorten the sidewalls, why the hell would i do that.
Old Oct 22, 2006 | 09:33 PM
d j's Avatar
d j
hukbong himpapawid
...you can go wider on a 17" wheel as you could on 18", you just gotta get the right offset and correct tire width. for 9" wide wheels, you mighrt wanna look into +30 or r+25. same thing for the rear jut use wider tires. but before you do that, you might wanna confirm if it will clear your brakes and you might need to roll your fenders if your car is lowered. do you have the sport suspension? i have stiffer spring rates on my coupe but I still think it's comfy enough for city driving.
Old Oct 22, 2006 | 10:23 PM
staticlag's Avatar
The Professor
my tires are stock! 30K miles baby... Well, except for the rear passanger... Brand new... and some damn unpredictable handling to go with it
Old Oct 23, 2006 | 11:25 AM
6speed's Avatar
College
Thanks! I never even thought about clearing the brakes. My suspension is stock but i plan on getting a sway bar kit (not sure what company to go with, or even where to start looking). Stiffer springs may be a plus, but i want to stick with the same ride height because theres a monster gutter dip into my driveway on one side (horse shoe). I'll have to head over to discount tire for info, they always know what to do (from my experience). Now...what size... I'd imagine 245/255 for the wide...so maybe 245/55/r17? i dont remember the per-inch conversion...any help?
Old Oct 23, 2006 | 12:45 PM
slavearm's Avatar
Boost Junkie
You can do 235/265 +40-50 up front and +43-47 rear.
I couldn't find a suitable way to get 275s to fit.
Old Oct 24, 2006 | 02:14 AM
6speed's Avatar
College
oh so 265 will fit, no rubbing up front? bc along with not wanting understeer, i want to be able to rotate them given i have a tendency to spin the tires from time to time. so a 265/50r17 will basically be the same height, with a 17 inch rim?
Old Oct 24, 2006 | 06:44 AM
slavearm's Avatar
Boost Junkie
265 should fit up front, you will just have to watch the offset. I have only had 245s up front, but there is easily another 20mm there to fit the 265.
Old Oct 24, 2006 | 06:47 AM
BigOLundh's Avatar
#1 Legend
This might help you for reference...
https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/enkei-rpm2-17x9-40-all-4-wheels-83496/
with a 9" rim and +40 offset.. i have room to spare. You should be able to go slightly larger.
-hS
Old Oct 25, 2006 | 12:33 PM
6speed's Avatar
College
as in a wider rim (say 9.5 inch front and rear) would clear with say a +45 offset? or do you mean taller BigOLungh. what should my tire size be also?
Old Oct 25, 2006 | 01:19 PM
kwescott's Avatar
One ball, corner pocket
I have 18x9.5 (+40) on all four...and am running 285's...no rubbing at all...even with the full MS suspension setup. It is all in the offsets.
I also have 19x8.5 (front) and 19x9.5 (rear)..with 245 front/275 rear. Again offsets are important.
Brake clearance shouldn't be an issue with 17's, but it definately would be an issue with 16's...this is why the auto (that came w/16's) have smaller front breaks than the GT version.
Old Oct 26, 2006 | 08:05 PM
6speed's Avatar
College
Originally Posted by kwescott
I have 18x9.5 (+40) on all four...and am running 285's...no rubbing at all...even with the full MS suspension setup. Brake clearance shouldn't be an issue with 17's, but it definately would be an issue with 16's...this is why the auto (that came w/16's) have smaller front breaks than the GT version.
so i should be looking for a 17x9.5 +40 offset with 265-285/55r17 and should be fine with all clearances. Sorry to bother but is 10 inch wide possible? is the offset in MM? Thanks alot guys.
Old Oct 26, 2006 | 11:57 PM
kwescott's Avatar
17x10 is possible....when I was looking at getting racing Harts, the recommended sizing (for staggered setup) was 19x10 in the rear.
yes, offset is in MM.
Old Oct 27, 2006 | 11:05 AM
6speed's Avatar
College
Correct me if im wrong, staggered setup is a difference in width of a vehicles tire size from front to rear. So im guessing 10 wide up front would rub, or require adjustments somewhere else. That is 2.0 inches wider than stock.
Old Oct 27, 2006 | 12:36 PM
kwescott's Avatar
yup....10 up front probably wouldn't fit without the proper offsets...even with the Racing Harts. I was surprised at how well my 18x9.5's fit front and back...not even close to having any clearance or rubbing issues.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
nferguson88
Oct 6, 2015 12:45 PM
GK1707
Sep 27, 2015 07:33 PM
