cigarette lighter
Old Oct 14, 2006 | 01:53 PM
WRXtoRX8's Avatar
Winning is Everything
cigarette lighter
So my girlfriend took the 8 into the dealer to get some things checked out while i am away. on the long list of things that i gave them which included moisture in the tail light i also had an issue with the cigarette lighter going out when we drove it back from texas. The service guy informed here that it is probably just a fuse but that it is not under warranty and would cost $50 to fix. I was like WTF is that!!! So he is supposed to check and verify that it is the fuse and let me know. that just seems like a crock of **** that it is not under warranty any more as the car only has 15K on it and is just over 1 year old.
Old Oct 14, 2006 | 02:36 PM
Tigster's Avatar
RX8 ADDICTED!!!
if it is a fuse then do it yourself they cost less than a buck.
Old Oct 14, 2006 | 02:42 PM
Freddie's Avatar
Yeah, that does sound like a crock. I think the warranty may in fact contain some exclusion to the effect that replacement items like fuses, light bulbs, wiper blades and the like are not covered. But jeez, checking and maybe replacing a fuse costs like what, less than one dollar and takes like what, one minute? Any decent dealer would do that just as a courtesy.
'Just curious, do you actually use the cigarette lighter to light cigarettes? Or, do you use the socket to power plug-in accessories. If you smoke, is it possible the lighter element is burned out (those cost about five dollars)? If you don't have a burned-out lighter or a blown fuse, then apparently you do indeed have a wiring problem.
In any case for the dealer to ask fifty dollars, or actually any money, to even look at this, is pure BS.
Old Oct 14, 2006 | 04:48 PM
WRXtoRX8's Avatar
yeah makes no sense that he told her that he would check it out for me at no cost but to actually change the fuse it would cost. I planned on just changing the fuse myself as i figured it was just that but didn't have time before I left and figured it would be covered.
Not a smoker i just use it for my car charger for my cell phone and sometimes a power inverter for my laptop. just a pain not to have that one working
Old Oct 15, 2006 | 03:01 PM
Half or more of the people will pay the $50
Nothing wrong, in fact he warned you up front. Now that's a good dealer.
Old Oct 15, 2006 | 04:05 PM
phroztbyt3's Avatar
ill explain how its not under warranty. You buy a cd player... the batteries go out.. r they under warranty?.. no.. cus theyre easily replaceable.
Ipod battery on the other hand is under warrranty because its built into the ipod per say.. a fuse is like a double a battery... u unplug.. and plug another in.. simple.
Old Oct 15, 2006 | 06:44 PM
WhiteDealershipRice's Avatar
I don't know... bumper to bumper waranty means just that.
While my toyota was under warranty they replaced the foglamps twice as waranty work (and they were a dealership installed aftermarket item)
I think bumper to bumper should cover it, but not powertrain warrnty
Old Oct 15, 2006 | 07:05 PM
Freddie's Avatar
Originally Posted by phroztbyt3
ill explain how its not under warranty... cus theyre easily replaceable.
You're right, that's pretty much what I said earlier . . .
I just think any dealer who wanted to ever see me back in their Sales or Service Department would take three minutes and do it free, as a courtesy.
Old Oct 15, 2006 | 07:08 PM
Freddie's Avatar
Meanwhile, yeah, I probably would have changed the fuse myself because driving to the dealer would cost more in time and gas. Actually we still don't know if the original problem of WRXtoRX8's girlfriend was the fuse or not.
Old Oct 15, 2006 | 08:24 PM
Shinka13's Avatar
You might want to check the amperage draw of your power inverter. The cigar lighter is only rated for 30 amps, and the accessory plug is rated for 20 amps. At least that's what the owner's manual says.
Old Oct 15, 2006 | 08:29 PM
NgoRX8's Avatar
dealers will screw you over... just change the fuse. take off the fuse cover next to the dead pedal and read the cover on what type of fuse it is.
i had to change a fuse and it cost me 3 bucks for two. lol.
Old Oct 15, 2006 | 10:59 PM
New Yorker's Avatar
I once thought my cigarette lighter stopped working. Turns out that by repeatedly plugging in my radar detector the little prong down in the base of the socket got pressed down too far. I pulled it back a bit with my finger and the cigarette lighter worked fine again.
Old Oct 19, 2006 | 11:17 AM
WRXtoRX8's Avatar
alright well got the car back this last tuesday, but I am still out of town and can't see the paper work. My gf did say they checked out the lighter and it is just a fuse so I will take care of that when I get back. still think it is stupid that they can take the time to check it but not change it for free. Unfortunately they also did not change the tail light out for the leak issue as he did not see the condensation himself, and said to bring it back when i see the build up again. This seems pretty messed up since I live in one of the driest states there is. The week before it was taken in there was moisture in the light and thankfully I was smart enough to take pictures of it but didn't have them printed before I left. I have to say as of right now I am not very satisfied with this dealership because of this light issue and the fuse issue.
Warrior777
Jun 24, 2019 04:47 PM
GK1707
Sep 27, 2015 07:33 PM
rooster
Nov 14, 2003 10:13 PM
RX8Lover
May 3, 2003 11:23 PM
