b&b midpipe + installation
Old Oct 12, 2006 | 08:27 AM
Acclaim99's Avatar
Just ordered a B&B race pipe to remove my cat... does the cat bolt off??
never did this before....
is it going to be extremely loud ? (ms dual exhaust)
Old Oct 12, 2006 | 08:40 AM
mysql101's Avatar
Cat comes right off. 3 bolts up by the engine, two (on springs) in the rear by the catback. My exhaust gaskets weren't in good shape once I took them off (they were sticking to the pipe and I had to use a screwdriver to get it off, in the process they were damaged), your local dealer can get you a new set though if this happens to you.
I don't know how loud it would be with the MS exhaust, but on a borla it was too loud for me and I ended up removing the borla temporarily (since it sounds fine with the stock exhaust).
As always, a turbo will make your loud exhaust setup sound nicer
Old Oct 12, 2006 | 09:10 AM
dgrx8's Avatar
FN GR8
i just ordered one too... gonna run it w/ the stock exhaust. i'm hoping it won't be loud at all...
Old Oct 12, 2006 | 09:13 AM
mysql101's Avatar
you can compare:
http://tyrannical.org/page-17
Old Oct 12, 2006 | 09:34 AM
dgrx8's Avatar
FN GR8
Thumbs up
thanks! i've been on that site quite a few times...
it's been really helpful but i just can't wait to hear it w/ my own ears.
Old Oct 12, 2006 | 12:50 PM
Acclaim99's Avatar
That BOV sounds crazy.
Doesnt sound too bad... my MS exhaust was pretty decent w/o the turbo, so Im hoping to get that noise back...
Old Oct 12, 2006 | 12:52 PM
Acclaim99's Avatar
Just realized that you have the same BOV, mine sounds way different
oops nevermind you have type s, i have type rs
Old Oct 12, 2006 | 12:59 PM
mysql101's Avatar
yeah, from the turbo eclipse from f&f fame
does that make a functional bov rice?
Old Oct 12, 2006 | 04:27 PM
Lasse wankel's Avatar
Lasse wankel
I must have heard about a 10 sound clips and they all sound the same to me! But... My own Swedish made Swedish quality midpipe with Ferrita race kat and 2.5" front silencer and with one rear sport silencer with 2.5" rear pipes sounds quite different becausse of much research and development i manage to let the Renesis engine sound like a deep tone chrisp 4 cylinder engine quite unique i can assure you! Video clips and sounds will be coming up in the next 2 weeks.
/Lasse
Old Oct 13, 2006 | 02:34 PM
dgrx8's Avatar
FN GR8
ok i just got mine installed. there is some weird vibration coming from underneath the car. it mostly happens when i pull out of a stop on first gear. what could this be??? it's really annoying!!!!
Old Oct 13, 2006 | 03:03 PM
maxxdamigz's Avatar
Baro Rex
Vibration as in the pipe hitting a cross member? Or more like sheet metal rattle? I put an RP supercat on and if I hit a good bump, it will tap a cross member. I'll get around to fixing it some day. Also, between about 3-4k RPMs at good throttle, it has a little metal rattle to it that I might be able to get rid of as well.
Old Oct 13, 2006 | 03:06 PM
dgrx8's Avatar
FN GR8
i think it may be like a sheet metal rattle. it doesn't sound like a metal on metal sound... it's mostly at low rpm... what could it be & how can i get rid of it???
thanks!!!
Old Oct 16, 2006 | 08:19 AM
dgrx8's Avatar
FN GR8
ok... this is driving me crazy!!!
there are rattles EVERYWHERE!!! ever gear... every RPM... i don't get it... what could this be???
there are even strange noises when i apply the brakes.
can someone please help
Old Oct 17, 2006 | 06:18 PM
OfficerFarva's Avatar
The cat comes off but the springs can be a bitch if u don't have a lift. I was under the car on jack stands when I installed my midpipe and I had to wrestle the spring shocks/bolts for a bit. But that was w/o air tools.
Old Oct 17, 2006 | 06:50 PM
Nopstnz's Avatar
The rattle may be there if you don't already have a hanger welded on. It could be bouncing around hitting things, sorry, dunno much about the b&b.
Old Oct 30, 2006 | 02:48 AM
Keef's Avatar
the shit starter
okay, I got the agency power system!! Sorry, not trying to jack this thread, but I get the same exact thing this guy is describing. My strongest rattling is 3.5 to 4 thousand rpm, that's when the metal actually starts to rattle...
I'm posting this cause I'm also running catless
Old Oct 30, 2006 | 07:11 AM
Digital_Damage's Avatar
humm... Don't have this issue with the turbo XS, could you post a picture of where the test pipe connects to the exhaust?
Old Oct 30, 2006 | 08:39 PM
dastallion951's Avatar
i had a similar rattling issue with my B & B midpipe n RB exhaust........problem was the pipe was leanin on the cross member......which would cause the rattling noise, n u wont hear it once u get goin becuz all u hear is the exhaust......check that and also make sure all your hangers r put on........
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
br0wm
Oct 24, 2015 11:06 PM
yapakanichi
Sep 25, 2015 07:55 PM
