stock system question
Old Oct 9, 2006 | 03:53 PM
chuuuma's Avatar
so i purchased my 8 about a month ago used and it has around 30k miles on it with the premium sound system. but how come when i press the text/ audio cont button on the dash it shows up as ALC OFF instead of Audio PLT on. i just read the manual and it says if the car is equippted with the premium sound system which is the bose system(i hope im right) if you press the button it should go Audio PLT On--> Bass--->treb--->fade--->bal---->beep on. but instead mine goes ALC OFF--->BASS--->MID--->TREB--->FADE--->BAL--->BEEP ON which is the standard audio equippted model. i hope u guys understand my question
Old Oct 9, 2006 | 04:00 PM
WikkedOne's Avatar
Deals on wheels
If you can look at your speakers and see a "Bose" tag on them you should have a bose head unit which should do what you want. If the speakers don't have the "Bose" tag on them.. then you got ripped off. but the good news is the HU is working correctly.
Old Oct 9, 2006 | 04:30 PM
New Yorker's Avatar
Yeah, sounds like you don't have the premium Bose system. Don't feel too bad—the general feeling here is that the premium system isn't that good. I have it and find its sound disappointing. I haven't compared the sound to the stock system, though.
Old Oct 9, 2006 | 04:37 PM
no dice's Avatar
I bomb atomically
Pick up a set of infinity 6X9's for the rears and a set of infinity 6800c's for the fronts and youll blow away the bose system in 4.1 seconds flat.
Old Oct 10, 2006 | 02:01 AM
chuuuma's Avatar
yeah i have the bose tag on the front speaker like the small 1 on the door
that's it tho
Old Oct 10, 2006 | 02:51 AM
The Ace's Avatar
Greek Power
Maybe you sell infinity speakers ?
Old Oct 10, 2006 | 10:36 AM
no dice's Avatar
I bomb atomically
no, i just believe in the product. :]
Old Oct 11, 2006 | 09:14 AM
UltraRX's Avatar
Are you running those speakers with everything else stock or some other setup? I'm assuming those are the 2 ohm Infinitys. (?)
Old Oct 12, 2006 | 10:59 AM
no dice's Avatar
I bomb atomically
Im running them at 4 ohms with an infinity reference 7541a.
111w @ 4 ohms x 4 or 139w @ 2 ohms x 4.
Its awesome. The amp has a hi-level inputs so you can go directly from the factory speaker outputs into the amp without the need for a line out converter :]
Old Oct 27, 2006 | 10:15 PM
cajunrx8's Avatar
Rotary Crawfish
Sounds like the P/O removed or replaced the Head Unit. May have broken and didn't like the price of new.
Old Oct 28, 2006 | 10:11 AM
vdelvec's Avatar
I'll tell you right now that if your radio has an option for MID, then you do NOT have the stock stereo system. It is most likely teh BOSE system. My stock stereo did NOT come with a MIDBASS option, only BASS and then TREBLE. Which is why I put an aftermarket Pioneer AVIC-Z1 in there. :-P
RA32425
Series I Engine Tuning Forum
10
Sep 8, 2015 08:53 AM
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
Espo
Aug 11, 2015 07:11 PM
