Weight of factory rims
Old Oct 9, 2006 | 09:43 AM
John Corbitt's Avatar
Does anyone know the weight of the factory rims, without the tire on it? I am debating on weather to replace them when I put new tires on, But I don't want heavier rims.
John
Old Oct 9, 2006 | 10:02 AM
CTrx8's Avatar
space for rent
i've seen everywhere from 21 to 25 lbs. you can do a search in the wheels section.
Old Oct 9, 2006 | 10:20 AM
StealthTL's Avatar
Metatron
Wink Wait.....
You could try the post in the Tech Garage section - the one entitled "Weight of Stock Parts".
It's stickied at the front of the section.
(....did you know that the plastic Engine Cover - 2.3lbs? )
S
Old Oct 9, 2006 | 10:29 AM
New Yorker's Avatar
I weighed one on my bathroom scale (weight with me holding one minus weight of just me) and it was 22 lbs.
Old Oct 10, 2006 | 04:37 PM
22 lb seems to be the number. In order for me to get significantly below that, I would have to spend over$2000 for rims that I like. I would rather save that resource for the afsc.
Thanks,
John
Old Oct 10, 2006 | 05:02 PM
PhotoMunkey's Avatar
Enkei RPF-1, 19" x 8.5" 42mm offset, 19.5#s per wheel. That there is a no-**** weight savings, even though 19" tires in a 245/35 width/profile combo weigh about 1 lb more per tire.
Old Oct 10, 2006 | 05:26 PM
Rosko350z's Avatar
I Heart 2nd Gear Racing
That's a great wheel, but if you're after performance, get 17's not 19's. Tires are cheaper. And obviously the 17" RPF1 weighs less than the 19".
Old Oct 11, 2006 | 01:38 AM
I like the Idea of going to 17's. Lower "rotational mass" is better for accelerating and braking.
John
New_Mazda_Guy
NW RX-8 Forum
Sep 19, 2019 11:20 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
duworm
Oct 1, 2015 04:57 PM
Stubbs
Sep 27, 2015 04:06 PM
