View Full Version : Evo brembo onto rx8?
Fluid4 10-03-2006, 03:03 PM can an evo 8 or 9 brembo be fix onto an rx8?
need to change the bracket rite?
any idea how much for the mod n bracket change after i buy the brembo from the evo guy?
thankz...
c h o x 10-04-2006, 10:01 AM can an evo 8 or 9 brembo be fix onto an rx8?
thankz...
That depends on what rims you're using currently. Our stock 18inch rims offset not enough if i'm not wrong...
Fluid4 10-04-2006, 10:39 AM mine is a 5mt...stock 16" only....
but will change to 18" rim before reg of the car ....
wat offset then can clear?
Why change to EVO Brembo??
A brake system is an integral system, from brackets to calipers to rotors to brake pads. A well design brake system will take into consideration the brake fluid pressure so that the car's ABS etc etc will not be affected after u fixed the after mkt brake.
U want to get a bracket made in a workshop in Yishun or somewhere, get an EVO Brembo and after fixing everything, it will be great?? It may look great but ... I just dunno if the approach is correct.
I know its a lot of savings but do look around, there are other brake kits, maybe even 2 pot but can be as good as other brake kit NOT designed for ur car.
My 2 cents.
Emperor 10-04-2006, 09:51 PM What you said makes sense. I do not know much about bbks but it seems to me that all use the same parts with different brackets or at least it looks that way. Maybe the UN- interchangability is just a marketing ploy to get people to plonk $3k upwards for something "exclusive"
I do hope its possible too. I have good lobang for used bbks.
Hi
At a recent ALCON presentation, it makes u realized designing a brake kit is not so simple. Manufacturer will decide how they want the system to perform, what rotor size to use etc etc.
For F1 and other com petition, 3 brands always comes up.. AP racing, Brembo and ALCON. If u look at any decent (and $$$) system be it Project Mu, Endless, brembo etc, they are not using the same caliper/rotor for diff cars. RX8 and EVO uses diff BBK set so its either marketing ploy or indeed they are different (diff weight, power etc etc).
So I am not too sure whether EVO BBK will be a good match with RX8. Then I oso dont know how u drive, how fast u drive, how u track etc. If normal driving, most BBK not that diff but during extreme driving/braking condition, it makes a diff. U may not use it so I cannot comment. Just feel that it is 'not so correct' to assume that Brembo means good becos 'incorrect Brembo' not meant for ur car may actually be bad during critical situation. Also heard story of some local fabricated bracket having some prob at track and M'sian highway so good luck when u get that bracket from ^&*% garage.
Anyway just my views so dont flame me. As to local fabricate braket, most workshop will have lobang. No prob with that.
Cheers
theboy 10-05-2006, 10:01 AM we got one rx8 with brembo brakes here in north borneo, kinda look good, but i think its for RX8 rather than Evo.
Fluid4 10-05-2006, 10:38 AM Why change to EVO Brembo??
My 2 cents.
so its better to get those capliers n rotor meant for rx-8?
like endless?
Fluid4 10-05-2006, 10:40 AM What you said makes sense. I do not know much about bbks but it seems to me that all use the same parts with different brackets or at least it looks that way. Maybe the UN- interchangability is just a marketing ploy to get people to plonk $3k upwards for something "exclusive"
wat kind of good lobang u have dude?
Fluid4 10-05-2006, 10:44 AM Hi
Cheers
tink i better go for endless thats mean for rx-8.....
u got any good lobang?
CoupeM 10-05-2006, 11:30 AM I think the evo brembo is actually using a smaller diameter rotor from us. So..braking power is probably similar to our single pot.
Ok straight off I know we have Endless BBk, Project Mu BBK for our ride. Re Amemiya has the AP racing (caliper only?), not too sure abt ALCON and AP racing.
Project Mu gives u the most option, they have 3 or 4 diff BBk for u to choose from from their slim series to their full racing 6 pot. Price of course diff depending on ur needs. I heard they use SCR Pro rotors which is very good news. thats the top, most ex rotor Project Mu produced. My fnd just fitted the forged slim 4x4 on his JDM Accord for $3600. Or u can try Monster Garage for the RE AP racing calipers.
What u need to check is support from agent (when time comes to replace brake seals etc) and everything original from Japan (esp brackets!). Rims on ur car must be able to clear the BBKs as well as replacement rotors/pads etc if the after brake comes with calipers only.
Sorry if I too lor sor.
Cheers
Hi
What I do know is many EVOs owners changed to after mkt brake becos the stock Brembo is not enough. Stock Brembos that comes with cars (EVOs, Integra Rs etc) are diff from after mkt Brembo kit u buy from the agent (eg Brembo GT BBK). They are smaller than their brethen.
For trackies, good BBKs are essential and design can go down to heat vane and not only 2 pcs floating disc design.
Cheers
Fluid4 10-06-2006, 11:57 AM Ok straight off I know we have Endless BBk, Project Mu BBK for our ride. Re Amemiya has the AP racing (caliper only?), not too sure abt ALCON and AP racing.
Cheers
thankz for the great info.....
one more ting...since rx-8 is rear wheel car ...then mean braking at the back more important?...i mean normal car just upgrade the front will do ...but i noe nuts abt rear wheel drive car...pls advise...thankz.....
No. Brake wise its still front BBK. Diff to find BBK kit for rear! Dont worry the designer oredi take care of front wheel or rear wheel car. I oso dunno how to xplain, maybe some bro here will.
Project Mu u can have 345mm rotor!! hehehe frighten everyone. If rims big and spaceous enuf, may be able to fit the 355mm rotor, then siao liao :ylsuper: :ylsuper:
Fluid4 10-07-2006, 12:20 AM No. Brake wise its still front BBK. Diff to find BBK kit for rear! Dont worry the designer oredi take care of front wheel or rear wheel car. I oso dunno how to xplain, maybe some bro here will.
i will be getting my car in 2 week time...
mine is the 5MT stock 16" rim but i changing to 18"...so should be able to clear rite?
any good place or lobang to change the brakes?
sorry to trouble u....too many question...
thankz for ur help...next time when i get my car n go for mit up...
remind mi to treat u dinner......
heheheheheeee
sqflyer 10-07-2006, 02:32 AM When you step on the brakes, the car's balance is shifted forward and consequently more braking can be applied on the front wheels than the rear. Therefore if you're going to upgrade your brakes, it makes more sense to upgrade your front brakes. It doesn't make a difference with front or rear wheel drive. Guess there's a lot to learn about cars if you're going to be selling them, eh? Better start doing some homework.
BTW, you also have to pay attention to front/rear brake bias and weight/power. Can't just get the biggest front brake rotors and calipers that can fit into your rims and ignore your rear. 355mm rotors and calipers add a lot of unsprung weight that your engine is going to have to push around so performance also affected. Modding also needs research.
CoupeM 10-07-2006, 02:59 AM Hi
Cheers
What I am saying is the evo brembo brakes are using smaller rotor so if we change to evo brembo is lppl. no point and a waste of money. I know tat many evo owners change to bigger brakes. then again most are running in the region of like 400 to 500 horses...more than twice wat we have in our 8
Fluid4 10-07-2006, 06:44 AM When you step on the brakes, the car's balance is shifted forward and consequently more braking can be applied on the front wheels than the rear. Therefore if you're going to upgrade your brakes, it makes more sense to upgrade your front brakes. It doesn't make a difference with front or rear wheel drive. Guess there's a lot to learn about cars if you're going to be selling them, eh? Better start doing some homework.
thankz forthe info.....
will buck up on my study on rear wheel drive cars......
need ppl like u to teach mi also mah...heheheheheee
Totally agree with u. Anyhow mod will make ur car even worse, totally out of balance. Talk so much my car BBK is still stock, just change brake hose and brake fluid. Now looking for brake pads. No need after mkt bbk cos stock brake good enuf for me liao... spend on bodykit to look good instead hehe.
Any bro here know where has ready stock of after mkt brake pads?? Need to buy soon.
Tks
Fluid4 10-07-2006, 10:30 PM Totally agree with u. Anyhow mod will make ur car even worse, totally out of balance. Talk so much my car BBK is still stock, just change brake hose and brake fluid. Now looking for brake pads. No need after mkt bbk cos stock brake good enuf for me liao... spend on bodykit to look good instead hehe.
Tks
wat brand hose n brake fluid u using?
our stock is 2 pot rite?
ngkenny 10-08-2006, 01:06 AM Totally agree with u. Anyhow mod will make ur car even worse, totally out of balance. Talk so much my car BBK is still stock, just change brake hose and brake fluid. Now looking for brake pads. No need after mkt bbk cos stock brake good enuf for me liao... spend on bodykit to look good instead hehe.
Tks
Ivan has autoexe in stock(me thinks)....
and ST power has APP pads in stock. saw it there last week.
OK tks bro.
Ivan paging u, got stock?? Mi want!
yiksing 10-09-2006, 09:31 AM Contrary to beliefs, changing the brake rotor or calipers to a bigger one doesn't make your brakes more effective. The better braking feel is merely a bigger effort exerted by the larger rotor, calipers equivalent to you stepping harder on the stock brakes. The way to improve braking is better tyres. Bigger brake rotors, calipers are not meant to improve braking effectiveness but rather to prevent brake fade.
Emperor 10-09-2006, 10:01 AM I would agree to that to some extent. The output force is still only a multiplied force exerted by your foot.
Now my new thought is that 4 pots is better than our stock, because our single pot brake pushes one way against a fixed caliper.
Do we really need the upgraded 4 or 6 pots? I doubt so, but i want one anyway. Seeing the prices of bbks, pads and lines seems a good value for money upgrade.
HI
1. 4 pot will give better braking becos forces applied to brake pads are more even.
2. Brake pads on big BBK usually have bigger contact area and hence better brake efficiency.
3. If u get 2 pcs floating rotor design, it helps dissipate heat better than single piece. The heat vane design on the rotor helps as diff design can mean diff ehat dissipation.
4. It is easier to brake with bigger rotor than smaller rotor. The force acting on the bigger rotor help stop faster.
5. The hose/brake fluid etc has higher heat tolerance etc etc
Do u need it everyday?? Maybe yes, maybe no. It depends on how u drive. If u got $$$, will u spend on it rather than on other mods?? Up to u but a good BBK will give u a lot of assurance hehehehe and look good.
Fluid4 10-10-2006, 02:12 PM I would agree to that to some extent. The output force is still only a multiplied force exerted by your foot.
u got good lobang for brake kits?
Emperor 10-11-2006, 12:28 AM u got good lobang for brake kits?
I have a good friend who deals in pre-owned performance parts. I can get the brakes but its the use of custom brackets that get me concerned.
coupe07 10-11-2006, 12:58 AM OK tks bro.
got!!
Fluid4 10-11-2006, 05:54 AM I have a good friend who deals in pre-owned performance parts. I can get the brakes but its the use of custom brackets that get me concerned.
wat brands he have?
