RX-8's For Sale/Wanted RX-8 Private Party listings, no Dealer listings
{ FS } 2004 RX-8, 6-Speed Manual for Sale
Old Feb 18, 2025 | 01:18 PM
FLCL's Avatar
Furi Kuri
GA 2004 RX-8, 6-Speed Manual for Sale
Year: 2027
Make: Mazda
Model: RX-8
Price: $3500
Mileage: 158022
Color: Gray
Location (US State/Canada/Int): AL
Mileage: 69,086 / 158,022
Grey / Blue Exterior w/ Cloth Grey/Black Interior
2004 Mazda RX-8, 6-Speed Manual for sale. Engine was replaced at 88,936 miles by Mazda, car body now has 158,022 miles. The new engine now has 69,086 miles on it. Maintenance list timeline and notes in an excel file. Car starts up no problem every time.
VIN# JM1FE173540112820
MODS:
BHR Motor Mounts
BHR Ignition System: Coils & Wires
BHR Midpipe, x2, one without a cat, and one with a cat. No cat version is currently installed.
Edelbrock Stainless Steel Clutch hose kit
StopTech Slotted Rotors
Speed Bleeders (for brakes)
Steel Braided Brake Lines
BHR Reinforced Clutch Pedal
BHR-CSF Radiator & New Mounting Brackets, new hoses & plastic clamp. Installed 1,690 miles ago.
Lightweight Pulleys (Crank pulley, water pump pulley, alternator pulley) & New belts. Old OEM pulleys in good shape and will come with the car, just not installed.
2 Rims recently un-bent. No bent rims on the car. 2 extra rims included.
REVi Intake System w/ Ram Air Duct
J-Spec Side Marker Lights (Clear)
LRB Speed Mazda RX8 Undertray + Uprights Under Engine Cover Tray
ZenSport Front Screen Set
RotaryFX Aluminum Rear Bumper Grille (Rotary Pattern)
Fender Vent Grill Set
Shocks & Struts - Coilovers - Megan Racing EZ II - 15-Way Adjustable - all 4 installed 1,200 miles ago.
4 New Tires - Toyo - 225/45R18 - installed 2,000 miles ago
Aftermarket Header - Never Installed but it goes with the car.
New battery - Installed on 2/5/25.
All recalls completed by Mazda.
Noteworthy Recent Repairs:
Water pump & thermostat replaced less than 2,000 miles ago. Also an extra brand new water pump comes with the car.
Radiator and 3 Main radiator hoses replaced 1,690 miles ago.
New Cooling Fans - whole assembly with both fans.
New Clutch, OEM, installed by Mazda 11,000 miles ago. (I had an aftermarket clutch but it kept giving issues, OEM one is much better for daily driving)
Issues:
Turning on Cruise Control will disable power steering. Keep cruise control off and power steering is active. Extra power steering control module will come with vehicle. (I swapped it out and it didn't fix the issue)
Some paint Fade on Hood mainly, some on Trunk and little bit on the front fenders.
Passenger Airbag Dashboard section cracked - Happened when Mazda did the recall work on that airbag. Said the car was too old and refused to replace.
Vehicle located near Athens, GA.
Paint Fade on Hood
Paint Fade on Hood
Another pic of Paint Fade on Hood
Paint Fade on Trunk
Paint Fade on Trunk
Shows a ding on passenger back fender
Aftermarket Header that comes with the car, but not installed.
Old Mar 9, 2025 | 02:53 PM
FLCL's Avatar
Furi Kuri
Sold - 3/5/25
mikeljourdann
Apr 25, 2024 08:07 PM
skippy1999
Oct 9, 2021 07:25 PM
itsallaboutgary
Oct 26, 2020 10:26 AM
