{WTB} JDM Aftermarket Front Strut bar(s)
Old Apr 6, 2021 | 06:25 PM
Federighi's Avatar
CA JDM Aftermarket Front Strut bar(s)
Category: Steering & Suspension
Price: $11111
Part Fits (you may select multiples): Series II
Hey 8Club!
Looking for Japanese aftermarket front strut bars for s2. I am not interested in the usdm mazdaspeed bar.
Just wanted to see if anyone had a new or used bar they're willing to part with before I placed an order. Primarily interested in Autoexe (msy400).
Thanks for looking!
Old Apr 10, 2021 | 03:53 PM
peterpangea's Avatar
If you don't need full J D M, there's a guy on here who has a corksport 4 point strut bar which I'm sure functions just as well as the autoexe...just sayin :P
Old Apr 11, 2021 | 06:23 PM
pretty sure he found what he was looking for already and this can be closed
short of someone coming up with the ultra-super-duper-unobtanium rare ARC Ti strut brace.
Old Apr 12, 2021 | 10:37 AM
Federighi's Avatar
Part found. Team is correct.
Mods please close.
Old Dec 6, 2021 | 12:26 PM
Federighi's Avatar
Still looking for an aluminum (or greater) quality front strut bar.
Old Dec 14, 2022 | 01:04 PM
Federighi's Avatar
Bump.
Still looking for a nice strut bar.
Old Jan 28, 2023 | 02:24 AM
JohnTheBastard's Avatar
Not to hijack the thread, but I figure folks following might know: does the Mazdaspeed strut bar fit on an S2? Everywhere I see it listed, it says 2004-08 only, but I feel like I’ve seen pics of S2s that have it.
Old Jan 28, 2023 | 10:12 AM
you gain the brake cylinder brace, but lose the triangulation to the firewall area, but it fits exactly the same as the S1. This is a 2010 (with other mods):
vs. the factory triangulated brace on the S2:
Which is why this WTB ad exists.
Structurally you’d be better off getting a fab shop to add a brake cylinder brace to the factory strut bar, but if you want the looks of the other more then you can do that.
Old Jan 31, 2023 | 01:37 PM
speed7's Avatar
To add to this.. when you take off the S2 strut brace you question if it's actually doing anything. Lots of the parts are slotted and the torque specs on the nuts is fairly low. I think if anything this bar is mostly to support the S2 engine cover. I've moved all of my cars to the mazdaspeed strut brace. AND you can still buy them new.
Front Strut Brace - Mazdatrix - MazMart - Atkins
Old Jan 31, 2023 | 04:59 PM
Federighi's Avatar
Still searching!
I thought I found a LHD MS 4pt but turned out to be a wild goose chase. Site advertises being in stock but I was unable to receive confirmation of driver orientation even after many email requests.
https://www.vividracing.com/mazdaspe...150746104.html
Let me know if you have something you're willing to part with.
Old Feb 3, 2023 | 04:37 PM
I tend to wonder how much any strut brace is really doing on a car with double wishbone suspension. I'd love to see measurements of actual deflection under torsional load with various 1st and 3rd party chassis stiffeners. My hunch is there's a lot of snake oil. Chassis stiffness was a major selling point for the RX8, so at some point you're just spending money and adding weight to chase vanishingly small improvements in stiffness.
The MazdaSpeed bar has some appeal for including the brake cylinder brace. I've already gone to stainless steel brake lines, but still would like a stiffer brake pedal. AutoExe makes a kit, but I've only seen it for RHD models. I've toyed with buying one just to have a fabricator make a mirror image of it for me.
Old Feb 3, 2023 | 06:41 PM
I ran without one in STX for several years
Old Feb 3, 2023 | 07:00 PM
Was there an obvious performance difference in the handling?
Old Feb 4, 2023 | 10:48 AM
not obvious and for min weight on street tires; ~2700 lbs. You can argue that Mazda had it on there for a reason, but that reason can be vibration and noise purposes more than stiffness. I’m sure it must contribute to some stiffness though, but the true magnitude is not so easy to define.
but for much stiffer springs and higher grip tires in DSP I have the MS one, but also have brake system mods nobody else is doing, or even thinking of. Otherwise the brake master cyl brace is a bit overrated on the typical RX8 imo.
Old Feb 4, 2023 | 11:26 AM
Federighi's Avatar
FYI. The MS 4 pt has the master cylinder brace as well. This one in the pic has been painted but still serves as an example.
I've been driving HPDE without a front strut bar for around a year now with no discernible difference imo (formerly used the AutoExe 6pt MSY480); other than a 10 lb weight reduction over the front end of the vehicle. I personally don't expect much of a 'performance increase' (if any) from a strut bar; especially on rx8.
Old Feb 5, 2023 | 12:39 AM
I… also have brake system mods nobody else is doing, or even thinking of.
Like what?
Old Feb 5, 2023 | 08:22 PM
apexglide's Avatar
So uh, how bad do you want that strut bar?
RX-8 ARC チタンタワーバー 程度◎ 激レア絶版品 ♪ SE3P MAZDASPEED マツダスピード チタン フルチタン 他NO507 /【Buyee】 "Buyee" Japanese Proxy Service | Buy from Japan! bot-online
Old Feb 5, 2023 | 09:45 PM
you can have one made for less that that; the name has no value in my book. Ti is everywhere now, so too laser cutting services etc.
Old Feb 6, 2023 | 10:56 AM
Federighi's Avatar
Wow, what a joke. Imo, car enthusiasm for rare / desirable parts is in a bad place these days. Primarily a bunch of hype, nonsense and price gouging.
Be cool to have and use but Team said it all.
Bravery
Mar 18, 2010 02:15 PM
dimitri_92
Jan 29, 2009 09:04 PM
pimpinjin
Sep 27, 2008 08:44 PM
scsi
RX-8 Racing
Aug 1, 2006 05:24 PM
Shocka
Feb 20, 2004 11:09 AM
