{ FS } Pettit Racing built engine (rew rotors) part out
![KY](https://www.rx8club.com/images/icons/ky.jpg)
Category: Engine - Complete Motors
Location (US State/Canada/Int): KY
The engine was built to be better for boost. The engine used Rx7 Rew engine rotors to lower the compression ratio and also use the much stronger / taller rew apex seals.
In order to run these rotors in the engine they had to custom machine new grooves into the sides to accept the 3rd Rx8 oil scraper ring.
The sides of the rotors were also machined to lighten them and add more clearance.
The full rotating assembly was then balanced.
The engine also has Pettit Racing porting done to the irons.
REW rotors with aftermarket apex seals / all other seals / machined / includes counterweights / eccentric shaft etc (Full rotating assembly) - $950
Rx8 engine irons ported by Pettit Racing ( All 3 irons ) - $500
![](https://i1370.photobucket.com/albums/ag253/shanegrf/Mobile%20Uploads/20190420_171421_zpss5yl6bbs.jpg)
This picture shows the size of the RX7 apex seals vs a new RX8 apex seal on bottom.
![](https://i1370.photobucket.com/albums/ag253/shanegrf/Mobile%20Uploads/20190420_171709_zpsojssvcyc.jpg)
![](https://i1370.photobucket.com/albums/ag253/shanegrf/Mobile%20Uploads/20190420_171411_zps42ta9qw1.jpg)
![](https://i1370.photobucket.com/albums/ag253/shanegrf/Mobile%20Uploads/20190420_170447_zpsoarcyzd1.jpg)
![](https://i1370.photobucket.com/albums/ag253/shanegrf/Mobile%20Uploads/20190420_170425_zpscx4ucmdz.jpg)
![](https://i1370.photobucket.com/albums/ag253/shanegrf/Mobile%20Uploads/20190420_170353_zpsb3yvxvin.jpg)
![](https://i1370.photobucket.com/albums/ag253/shanegrf/Mobile%20Uploads/20190420_170336_zpsyih1pbwr.jpg)
![](https://i1370.photobucket.com/albums/ag253/shanegrf/Mobile%20Uploads/20190420_170323_zpsrxpgcj9g.jpg)
![](https://i1370.photobucket.com/albums/ag253/shanegrf/Mobile%20Uploads/20190420_170247_zpszb01dgse.jpg)
![](https://i1370.photobucket.com/albums/ag253/shanegrf/Mobile%20Uploads/20190420_170234_zps22tua1mk.jpg)
![](https://i1370.photobucket.com/albums/ag253/shanegrf/Mobile%20Uploads/20190420_170046_zpsx5egbxsj.jpg)
![](https://i1370.photobucket.com/albums/ag253/shanegrf/Mobile%20Uploads/20190420_170012_zps3o0k56zy.jpg)
![](https://i1370.photobucket.com/albums/ag253/shanegrf/Mobile%20Uploads/20190420_165941_zpsgtmydziq.jpg)
![](https://i1370.photobucket.com/albums/ag253/shanegrf/Mobile%20Uploads/20190420_165805_zpsvrjb7ztz.jpg)
![](https://i1370.photobucket.com/albums/ag253/shanegrf/Mobile%20Uploads/20190420_165718_zpsxtp7gw5f.jpg)
chironwsc
08-30-2008 02:37 AM
Philip_SA
11
05-02-2007 05:34 PM
rotarygod
05-02-2004 08:02 PM
