{ FS } Maxim Works / AutoEXE Header + OBX Midpipe
Old 02-21-2016, 06:41 PM
CustomMSP's Avatar
Category: Engine - Exhaust
Location (US State/Canada/Int): NC
For sale is my Maxim Works header.
Header is in perfect working condition, no cracks or leaks. Maxim Works manufactures this same header for AutoExe. It features a beautifully done merge collector. Take a look at the pictures. The outlet flange requires a 2.92" ID ring gasket so I modified a new Mazda ring gasket by removing a few of the inner layers and it will be included with the sale. The OE header doesn't have that lip that this header does, but this lip acts as an extra seal against the lip of the midpipe inlet flange. The support bracket is not included, but the stock bracket does a good job as a place for the header to rest on and allows for expansion / contracting with the heat cycle.
Maxim Works product page
Header Sold
Attached Thumbnails Maxim Works / AutoEXE Header + OBX Midpipe-20160221_163541.jpg   Maxim Works / AutoEXE Header + OBX Midpipe-20160221_163551.jpg   Maxim Works / AutoEXE Header + OBX Midpipe-20160221_163609.jpg   Maxim Works / AutoEXE Header + OBX Midpipe-20160221_163650.jpg   Maxim Works / AutoEXE Header + OBX Midpipe-20160221_163704.jpg
Maxim Works / AutoEXE Header + OBX Midpipe-20160221_163717.jpg   Maxim Works / AutoEXE Header + OBX Midpipe-20160221_163747.jpg
Old 02-24-2016, 08:39 AM
2hit6's Avatar
PM'ed
Old 02-24-2016, 10:50 AM
coolcars44's Avatar
email me if you still have the midpipe usedcarpartss@aol.com
Old 02-29-2016, 04:43 PM
Rotary Lover
0VER9K's Avatar
how much for the header?
Old 03-01-2016, 10:57 AM
Rotary Lover
0VER9K's Avatar
Nice, will this piece throw a CEL and do i need to re-tune to get the most out of it?
Old 03-01-2016, 11:04 AM
CustomMSP's Avatar
There shouldn't be any issues with CELs if installed properly. No need for a re-tune as the dynamics of the engine won't change much, but a good tune is always a good thing, especially if the cat has been removed.
Old 03-01-2016, 11:11 AM
TX
Installing the header won't in itself cause a CEL, but if you delete the cat or remove the air pump it will cause a CEL.
Installing a header does change the volumetric efficiency of the engine so to take advantage of it you need a tune, otherwise it's a worthless modification.
Old 03-02-2016, 08:25 AM
acroy's Avatar
PM'd
Old 03-09-2016, 11:52 AM
Life After 8K RPM....
Khurram's Avatar
Hi There,
do you still have the header?
Cheers,
Old 03-09-2016, 01:36 PM
CustomMSP's Avatar
Sold, bud.
Dr.Hyde
04-06-2012 08:32 PM
Never L8
07-18-2010 09:36 PM
RotaryChik59
02-19-2009 09:10 AM
iewgnaw
04-07-2008 06:15 PM
Quick Reply: { FS } Maxim Works / AutoEXE Header + OBX Midpipe
