{ FS } NGK BUR9EQP Leading & Trailing plugs for boosted 8's + One way check valve
Old Aug 3, 2015 | 12:49 PM
Sifu's Avatar
Opulence
Price: $55
Location (US State/Canada/Int): TX
Brand new in box. Parts and info came from RX8 Performance.
The total for parts came out right under $70. Plus $20+ in shipping.
Asking for $55 shipped + paypal fees if necessary.
Pictures are found on my Flickr: https://www.flickr.com/photos/9523646@N04/shares/UkpazW
Here is some info on the plugs:
NGK platinum spark plugs are a surface gap type plug used ideally for use in boosted rotary engines. The leading plugs are a colder heat range which reduces the chances of engine damaging detonation or "pinging". These are aftermarket plugs and are gapped.
Info on the one way check valve for the boosted 8's:
If you are have forced induction on your RX-8 and do not have our check valves installed, you likely have a boost leak!
In most applications when the intake manifold becomes pressurized boost is forced back to the intake from two tubes.
1) The Jet Air Mixing Nozzle tube attached to the lower intake.
2) The factory oil metering tube check valves are known for failure and under boost the oil is pushed back up the metering tubes. This leaves the engine without oil injection until the oil works its way back up the tube. Once the engine is under boost again, the problem returns.
Old Aug 10, 2015 | 08:51 AM
Sifu's Avatar
Opulence
Don't need this anymore! Willing to take offers to unload these parts.
Old Aug 23, 2015 | 07:44 PM
Sifu's Avatar
Opulence
Bump!
Old Aug 30, 2015 | 10:51 PM
Sifu's Avatar
Opulence
Sold!
Dokuji
Nov 1, 2016 02:51 PM
GK1707
Dec 2, 2015 10:01 AM
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
