{ FS } Aluminum Radiator
Old 09-16-2013 | 08:12 PM
Arca_ex's Avatar
BECAUSE RACECAR
Aluminum Radiator
Category: Drivetrain
Price: $325
Location (US State/Canada/Int): AZ
So, I had CSF Racing Radiators make me an all aluminum radiator, and they accidentally shipped two. One to me and one to my local vendor for CSF products that I worked with to acquire the radiator. I now have both of them in my possession and am looking to get what I paid for it so I can square up with my vendor since he was charged for two units.
This radiator is nearly double the thickness of the stock one, the core is 52mm (a little over 2"). I'm not sure if the A/C condenser will still fit on the front of it without a little modification to the A/C hardlines (bending them) but it does have the mounting holes for the A/C condenser on the front. Fitment at this point is unknown, I haven't mounted mine, but all the holes seem to match up perfect. I have installed CSF OEM Replacement radiators in some of my other vehicles before and fitment has always been dead on with those units, I would expect this one to be the same.
$325 shipped to the lower 48, payment accepted through PayPal.
I only have one picture right now, can get more if requested.
Attached Thumbnails Aluminum Radiator-1277671_10151908316377533_894036875_o.jpg
Old 09-17-2013 | 01:43 AM
logalinipoo's Avatar
Driving my unreliable rx8
PM'ed
Old 09-17-2013 | 10:53 AM
Arca_ex's Avatar
BECAUSE RACECAR
Sold.
If anyone else would like one of these though you can PM me and I can put you in contact with them.
Old 09-17-2013 | 11:53 AM
Damn it.
Old 09-17-2013 | 06:01 PM
Originally Posted by 9krpmrx8
Damn it.
HAHA, I'll let you know how it works.
Arca, Is this a radiator they make normally or is it really custom? If so what's the differance in it. Also you are Paid Sir.
Old 09-17-2013 | 06:55 PM
BJP's Avatar
BJP
That went quick
Old 09-17-2013 | 08:07 PM
Arca_ex's Avatar
BECAUSE RACECAR
Sounds good, will ship it tomorrow afternoon.
This radiator is kind of in between "normal" and "custom". They already had the dimensions from when they were making a radiator for Stillen and I believe they made a handful recently with the latest revision of their 2 row core that are much thicker, but they aren't really available for purchase anywhere at all. They're not even listed on their own website, but a few exist and they have the capability to make more if there is interest.
The biggest features of this radiator are one piece end tanks instead of welded together plates of aluminum, and the core has specially designed "B-Tube" rows that give it more surface area to dissipate heat.
Old 09-17-2013 | 11:37 PM
Warrior777's Avatar
Any way you can post more pictures and let me know if the stock condenser will mount up when you figure that out?
Old 12-19-2013 | 07:48 PM
My radiator fit great and dropped cooling temps considerably at temp. The day I replaced it was 100+ out and before replacing it I was seeing crusing temps on the highway of up to 210F. About 2 hours later with the same ambient temps I was down to 190F. That is with no other mods. I went and bought some foam to seal it up. With the foam in a few hours later I was crusing at 182-183F, but the tempature dropped into the upper 90's by that time.
It fit Tight, but It worked. I had to start the bolts on top and tighten them at the same time. The battery tray was a little tight to get back in, but otherwise I had no problems with it at all.
Old 12-20-2013 | 07:22 AM
WaitingforFI's Avatar
Add gas, add oil, repeat
Were the AC lines any issue?
Old 12-20-2013 | 05:46 PM
No, i left the Fans and AC condensor in the car and just dropped the radiator out from between them. I had to bend one hard AC line about 1/2".
I left the yellow protector on until I had the radiator in place. Then I had a hard time removing the protectors, but it was not bad. I used PVC pipe cement to glue the foam into place and it is still holding great.
Old 05-21-2014 | 03:04 PM
Warrior777's Avatar
So my buddy and i bought the csf radiator, he installed his a month ago, everything went great. Radiator looks like awesome quality and bolted right up. He is at hallett raceway today its about 90 degrees ambient temp. He texted me saying he stopped because his temps were climbing to 240's and he did not want to over heat. Besides the radiator he has the misimoto thermostat which opens at 169 coolant temps and the remedy water pump. No fan mods. He is doing 15 minutes high speed touring sessions. Anybody have similar issues?
Old 05-21-2014 | 03:17 PM
Why would you install a Mishimoto thermostat? Was the engine blocked drained and the system bled as per the FSM? How many miles are on his water pump? Any coolant loss?
Old 05-21-2014 | 06:10 PM
he should have stopped sooner
otherwise there are similar threads regarding cooling at the track in the racing forum that this might be better served to be posted there instead
Old 05-21-2014 | 08:53 PM
Warrior777's Avatar
Yes the engine block was drained per FSM, he is using a brand new re-medy water pump, probably a few hundred miles on it now. No coolant leakage. I really don't know why he went with the mishimoto thermostat over the re-medy but the mishimoto was installed at the same time as the csf radiator.
We will be installing the rx8performance fan mod here in the next couple of weeks.
TeamRX8, i will get to posting in other threads. Just want a quick pole from some of the guys with this particular radiator.
Old 05-21-2014 | 09:37 PM
Arca_ex's Avatar
BECAUSE RACECAR
Did he do any ducting? Does he have an undertray?
Old 05-21-2014 | 11:05 PM
Warrior777's Avatar
Yep we kept the stock foam and made sure everything is in place! Yes stock undertray is being used.
Do you think it's a possibility the CSF radiator is more of a step back of this application when compared to the stock rad?
Old 05-21-2014 | 11:54 PM
I can't talk about track use, but I drive it about as hard as I safely can on the street and the CSF radiator made a noticable difference in cruise my temps.
I am running
2 parts reverse osmosis water to 1 part coolant
royal purple equivalent of water wetter
Remedy thermostat
stock water pump
newer stock hoses(2 years old 6K miles)
Custom radiator ducting
Last week temp's in the mid 94-95 I never got over 210. When I let off temps drop right to 180. My temps get up to 208 while idling, but i think that's due to stock fans going out.
Old 05-22-2014 | 09:38 AM
Arca_ex's Avatar
BECAUSE RACECAR
No, this radiator is bigger and has the ability to shed more heat than the stock unit. There has to be something else going on. There are guys here at the track with CSF radiators on 500+WHP Subarus and they never have cooling issues even with front mount intercoolers.
02-27-2020 08:39 AM
TotalAutoPerformance
Vendor Classifieds
12
10-17-2018 09:00 AM
olyrx7
10-26-2015 09:23 AM
archon
10-01-2015 06:08 AM
09-30-2015 01:53 PM
Quick Reply: { FS } Aluminum Radiator
