{ FS } Moton ClubSport coilover shocks for 2004-2008 RX8
SOLD - Moton ClubSport coilover shocks for 2004-2008 RX8
Category: Steering & Suspension
Price: $2995
Location (US State/Canada/Int): NC
For sale - full set of Moton ClubSport dampers for 2004 - 2008 RX-8. Excellent condition - no leaks, damage, or any other issues.
Returning my RX-8 to stock, so I have no need for this coilover shock package anymore. Purchased in early 2011 and used for STX class autocross (13 events) and 2 HPDE track events at VIR, approx. 3000 miles total. Never daily driven.
Independent compression and rebound damping adjustment (7 positions each), simple adjustability for handling performance and ride quality. For additional info, see Moton Club Sport Damper System Mazda RX8 03-08
Includes the following springs, based on set-up recommendations from multiple national level autocrossers (see also Sport Compact Car RX-8 STX Set-up Article):
*Front - Hyperco 8A0500; 500lb/in; 8" length; 2.25" inside diameter
*Rear - Hyperco 7B0350; 350 lb/in; 7" length; 2.50" inside diameter; plus zero rate helper spring
The front shocks are fully assembled, ready to bolt on and go, including Moton spherical bearing top hats and Moton 2.25" spring perches.
The rear shocks only require installation of Mazda upper mounts from your OEM RX-8 rear shocks (or an aftermarket upper mount).
Also included are the following tools and spare parts, as shown in the photo below:
*Pair of custom spanner wrenches (for ride height adjustment)
*Extra set of zero rate helper springs
*Set of front 2.5" ID upper spring perches (anodized aluminum)
*Set of front 2.5" ID height adjustable lower spring perches (anodized aluminum)
*Pair of bumpstops
*Extra set of rear 2.5" ID upper spring perches (delrin)
Current spring height setting is 1" drop from stock ride height.
Asking $2995 for the complete set. Local pick-up in Cary, NC is free; Ground shipping to anywhere in the continental US is $50 flat rate.
Additional photos can be seen at Photobucket Album
Please contact me (Keith) by PM or at (919)306-1674 with any questions or if interested. Located in Cary, NC.
Brandonien
07-30-2015 12:33 PM
philip53
07-30-2015 04:18 AM
