Non-Rotary Swaps Engine Swap Forum
Kickers V6 swap thread
Rating: Thread Rating: 9 votes, 5.00 average.
Old 05-28-2016, 03:20 AM
  #1176
toniok's Avatar
Originally Posted by kickerfox
Know what's funny? It took less research to figure out what parts will bolt together to make my entire drivetrain fit the car then it's taking to put a fuel filter on it.
Lol sounds about right, the complex is easy, the simple is hard. If only I could convey that concept to my wife; "You said you were 90% done a week ago, why aren't you finished?"
Keep at it, your build inspires me.
Old 05-30-2016, 12:12 AM
  #1177
kickerfox's Avatar
Well now I'm screwed. The valve cover is hitting the brake booster. I have no idea why because one of the first things I did was put the engine in the bay and center it and it cleared everything.
The valve covers are magnesium and I don't know if it could be notched. Can't notch the booster because it's hitting where the seal is. Could try and find another booster but finding one that'll bolt to the firewall would be nothing less then a miracle plus the master diameter would have to be the same. Firewall design makes it hard to shift the master over but not impossible. Can't shift the engine over without screwing up the driveshaft alignment. What to do what to do....
Old 05-31-2016, 10:00 PM
  #1178
Unregistered User
stickmantijuana's Avatar
if the engine is already mounted, you can always try electronic vacuum booster with master cylinder and get rid of the entire donut. They have small pumps providing vacuum and much smaller.
Old 06-01-2016, 12:44 AM
  #1179
kickerfox's Avatar
Sounds expensive. I'll probably take a stroll through the yard and see if there's something I can make fit. I'm near the point where shortcuts are going to have to be made like ABS elimination. Defeats the purpose of my build when I start doing things like that.
Old 07-29-2016, 12:24 AM
  #1180
Tunkka's Avatar
Just do it. Find out what you can not do and than go and do it... At the end who cares if ABS will be eliminated or some parts will be cut off? Go and enjoy the ride...
Old 09-21-2016, 09:26 PM
  #1181
kickerfox's Avatar
Willwood 3/4 and "stage 3" camaro clutch set playing nice together.
Old 09-25-2016, 01:02 PM
  #1182
KFC
KFC's Avatar
Hey kickerfox,
Did you manage to sort you're clearance issue with the brake booster? Did you find a smaller one? I'm not sure I understand doing without the booster all together and running a vac pump? I thought they are a mechanical assist on the master cylinder push rod?
I'm not sure if you know but my car is done and I've been driving it around for a couple of months. It's had some teething issues but still great! It could use some more power though..
Old 10-03-2016, 01:10 PM
  #1183
kickerfox's Avatar
Originally Posted by KFC
Hey kickerfox,
Just bump up the displacement 700cc and add a pair of T25s. That's what I'm expecting to have when this is all said and done.
I'm going to notch the subframe like they do on LS swaps. I think if I can get the engine down a hair I'll be ok. If not, I'll find a smaller booster. There's plenty of room to come forward with one if I had to. Chances are I'd have to make a spacer/adapter between the booster and the firewall. It's frustrating, but not impossible to correct. All things considered to date, it's a minor setback.
Old 10-03-2016, 01:16 PM
  #1184
kickerfox's Avatar
Been a long summer but many other projects were completed. I'm certain I can get the rest of this build finished over the winter. All the major things are complete. Just need to get the engine mounts finished, plumbing and wiring, and make a new PPF.
Spacer for clutch slave.
Old 10-13-2016, 06:42 PM
  #1185
kickerfox's Avatar
Using this site on Android reminds me of AOL over 28.8k dialup on my i386 desktop of 20 some years ago. Technology is over-rated.
Ebay sent me the wrong parts yet again. In the mean time I've been working on the plumbing. I'll be reusing the drivers side RX8 oil cooler since it conveniently has a thermal bypass in it. Ordered some 18mm banjo to -10 adaptors that fit it since the rest of my oil lines are -10. Nice and easy.
Old 10-18-2016, 03:12 AM
  #1186
Tunkka's Avatar
Did you keep two oil coolers or leave one as to be good enough for cooling your engine setup?
If you have two of them can you put some drawing diagram of the route of the pipes please?
Old 10-18-2016, 06:06 PM
  #1187
kickerfox's Avatar
I'm only using the drivers side cooler. It's more then adequate for a piston engine.
Old 10-27-2016, 06:15 PM
  #1188
suicide-racer's Avatar
Don't know whether to read from the start or hunt for where the actual building starts. Some amount of pages.
Cheers John
Old 10-30-2016, 07:05 PM
  #1189
kickerfox's Avatar
Upper radiator hoses.
Old 10-30-2016, 07:10 PM
  #1190
kickerfox's Avatar
Cheers John
Just skip thru it. I think mockup and fab starts on page 26 or somewhere around there. Scroll for photos. Most of the relevant notes accompany a photo.
Old 10-31-2016, 01:29 AM
  #1191
kickerfox's Avatar
Mocking up some of the charge tubing.
Old 10-31-2016, 08:09 PM
  #1192
kickerfox's Avatar
Looks nice in there.
Old 11-02-2016, 03:18 AM
  #1193
kickerfox's Avatar
Can't forget the AC. Lucky me. The RX8 pressure side fits the Isuzu AC compressor. I just need to rotate the fitting to line up the bolt. The low side was moved closer to the firewall. At the compressor, the Isuzu line winds up in the same place but will have to be spliced to the RX8 line.
Old 11-08-2016, 04:13 PM
  #1194
kickerfox's Avatar
AC lines - done
Coolant lines - done
Heater lines - done
Oil lines - done
Left to do:
Vehicle side engine mounts.
Shorten driveshaft.
Make PPF.
Fuel return line.
Modify engine harness.
Old 11-10-2016, 12:17 PM
  #1195
David Hagler's Avatar
How is your project going on your v6 ??
Old 11-10-2016, 11:53 PM
  #1196
kickerfox's Avatar
I've posted the most recent updates. It's coming along. The vehicle itself is bothering be. It's rusting just sitting in the garage. The rockers are probably pretty thin. Sad for only 74k. I'm keeping an eye out for the southern blue roller. I'll swap everything over if I find a clean one.
Old 04-07-2017, 11:19 PM
  #1197
Dr.G's Avatar
Kickerfox thank you thank you thank you. For this build thread. I came up on a 6VE1 we had laying around the shop and once we noticed that the bell housing matched that of my 2.5L Jeep the internet searching began. Your thread has been a great resource and because of it I now have a 3.5 V6 6VE1 from an 02 Axiom powering my 1992 Wrangler. Your flywheel photos and posts on other forums have made working through the unknown almost seamless. The AX5 transmission with internal slave cylinder worked perfectly.
I hope to see your RX8 run and drive soon. My Jeep is in it's final stages then it's off to see if it will sneak through emissions. Again thank you!
Old 04-16-2017, 07:24 PM
  #1198
kickerfox's Avatar
Glad you found something useful. Isn't this engine just "universal as f"? lol
Old 04-27-2017, 06:43 PM
  #1199
JFAllen's Avatar
Been periodically checking in on your progress.
It's still awesome . Makes me keen to bite the bullet and do this to my Datsun 180b (610)
Keep up the good work.
Jordan
Old 06-11-2017, 01:27 AM
  #1200
kickerfox's Avatar
Due to this site being totally unusable on a mobile device, I'm moving the build thread elsewhere.
Thank you everyone who's enjoyed the swap!
You have already rated this thread Rating: Thread Rating: 9 votes, 5.00 average.
Quick Reply: Kickers V6 swap thread
