{ FS } oem motor parts and others,vent gauge pod
Old Mar 15, 2011 | 08:43 PM
bumblebeerx8's Avatar
Rear Mount GT35R
Category: Engine - Intake/Fuel
Location (US State/Canada/Int): OH
prices do not inclue paypal or shipping. I should be able to use flat rate boxes and usps for most of the parts.
2 sets of oem coils one with 21k other with 29k 15 each, 50 set
1 set of magnacor wires and one set of oem 20 for a set
oem pullys 10 each 45 for set
oem coil bracket 10
alt. bracket 10
i believe the air pump control modual 20
lower part of umi 40
uim 90
oem water pump 20
oil filter thread 30
oil fill (no solenoids 50
long red fuel line 20
fuel rail connection line 10
blue fuel line 15
primary fuel rail 20
sec. and p2 rail 50
set of injectors 130
oil cooler lines 100
main wiring harness (one injector wire clip broke where to press down to release)120
oem oil pressure sender 5
altanator with pully 225
oem water temp sender 10
throttle body coolant lines 10 each
oem thermostat 10
oem center dash cover with bose speaker 75
helix tb spacer 30
oem oil pan 60
if i find or think of more i will add them
Old Mar 15, 2011 | 08:53 PM
chino0314's Avatar
Dibs on vent pod pm me
Old Mar 15, 2011 | 09:21 PM
Rear Mount GT35R
vent pod sold. that didnt last long
Old Mar 16, 2011 | 01:06 AM
shadycrew31's Avatar
WENTGERMAN
I was just about to pm you about that to... Dam!
Old Mar 17, 2011 | 09:22 PM
Rear Mount GT35R
Old Mar 24, 2011 | 05:41 PM
Rear Mount GT35R
Added:
oem intake tray 35
oem exhaust manifold 45
Old Apr 2, 2011 | 02:44 PM
Rear Mount GT35R
bump front main pulley, and ignition triger plate sold
Old Apr 2, 2011 | 06:13 PM
USMC_Skip's Avatar
Boosted Marine
Where did you originally get the vent pod?
Old Apr 2, 2011 | 11:50 PM
Rear Mount GT35R
i bought it from a member unused then i never used it. I believe it came from here this is thew dual version he does also make a single http://www.mazdas247.com/forum/showt...od-for-the-Rx8
Old Apr 24, 2011 | 12:43 PM
Rear Mount GT35R
Old Apr 26, 2011 | 01:20 PM
stinksause's Avatar
The Stink w.o The Sause
would you be willing to sell just two yellows?
Old Apr 26, 2011 | 09:09 PM
Rear Mount GT35R
^clear your pm box
Old Apr 26, 2011 | 11:53 PM
WhiteSnowflake8's Avatar
Diego
i may grab oil pan, do you happen to have the passenger oil cooler brackets with hardware?
Old Apr 27, 2011 | 06:02 AM
Rear Mount GT35R
i have one bracket not sure what side. no hardware though
Old Apr 27, 2011 | 06:32 AM
L337fpc's Avatar
ლ(ಠ益ಠლ)
might you have a spare VDI?
Old Apr 27, 2011 | 09:33 AM
Rear Mount GT35R
i would have to pull it out of the LMI and get you a price. do you need just the internal part or just the acuator or both?
Old Apr 27, 2011 | 09:35 AM
L337fpc's Avatar
ლ(ಠ益ಠლ)
probably both, mine just died and ive got a track day in ~2 weeks. So i'm scrounging around trying to find one...that or i'll just suck it up and buy a new one.
Old Apr 27, 2011 | 06:16 PM
Diego
Post a pic and i will tell you what side it is.
Old Apr 27, 2011 | 07:09 PM
Rear Mount GT35R
I know they are stamped with the side. I just do not have part where i live the car and others are at my dads house. i 80% sure its the driverside. Ill let you know by friday night.
Old Apr 27, 2011 | 08:26 PM
Diego
sounds good, thanks!
Old Apr 28, 2011 | 03:51 AM
mushkid's Avatar
Smile,It confuses people!
I'm looking for a fuel pump
got any on sale?
Old Apr 28, 2011 | 05:44 AM
Rear Mount GT35R
I don't have a housing. I can do 40 shipped pm me for PayPal info
Old May 4, 2011 | 06:07 PM
Rear Mount GT35R
to the top
Old Sep 4, 2011 | 11:52 AM
pt12288's Avatar
do you have the oem intake ??
Old Sep 4, 2011 | 01:28 PM
Rear Mount GT35R
what part? upper (which piece) or lower? not sure if the 4 port is different but this is off a 6 port.
Kahl
Aug 20, 2015 11:49 PM
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
06rx8nate
Aug 4, 2015 08:29 AM
escapedan
Series I Do It Yourself Forum
Jul 29, 2015 10:44 PM
