{ FS } Full Interior Partout
TeethNThings.com
on
Category: Interior
Location (US State/Canada/Int): OH
I am taking my car from street to full dedicated track car. I'm parting out the interior parts in preparation for roll cage installation. The car had 40,000 miles and all parts are in good condition.
Photos are the stripout are available at: http://domomotorsports.com/about/Flash02/index.html
I do not plan individual photos unless there are scratches on parts you need.
Please be patient with response time.
Reach me directly at mark@domomotorsports.com
If you are interested, you can follow the car buildout at http://domomotorsports.com/about/about.html
11-2-10- Added some parts diagrams for easier communication
FULLY SEMI AUTOMATIC
not sure what its called, but i want the piece under the steering wheel. the one that has a "u" shaped cut out for the tilt release handle.
I need the two rear seat grab handles and that piece that you remove from rear center pass-thru so that you can put a long 2x4 in the trunk.
If you are taking the steering wheel plastics off, I will need the top part of the steering rack cover. I mounted some gauges there and now I have holes.
Mark---- I just realized you have the 04 model? That harness will not work for me as I need the one that has the wiring for the weight /slide rail sensors. The 04's dont have that. Dang.
Anyway--good luck with the build. In the SE with NASA a really good friend of mine with a 2005 RX8 is in line to win the TTD champonship this year IF those pesky S2's will leave him alone![Smilie](https://www.rx8club.com/images/smilies/smile.gif)
Guard your points---the RB stage 2 flash does help midrange a lot --at the expense of long engine life and increased temps
Also the 09 trans helps a good bit.
The syncro saver actually will reduce your lap times as you can bang the gears a lot faster without risk of overshifting. Being an old drag racer I know the importance of getting the car back in gear and on power. I was surprised also of how much easier it is to downshift with it. Best $90 i have ever spent.
Good luck with the addiction![Smilie](https://www.rx8club.com/images/smilies/smile.gif)
OD
OD
TeethNThings.com
on
Olorin2: I emailed you back.
Thanks OD. I took third in Great Lakes at NASA this, my first year. Hopefully, with some added experience and the car upgrades I'm aiming at TTD region champ 2011. Nationals are at Mid Ohio this year, so some added incentive.
I already put in the short shifter and synchro saver after the season, so I'm looking forward to that. I can't do the 09 tranny due to points.
Email me if you want to talk a little. I've had some great help from some great people here. Special kudos to Eric Meyer and Charles at Black Halo. GREAT people!
