___________25mm (1inch) spacers 5x114.3 ______________
These spacers are solid billet aluminum and are of high quality. The center bore size is 2.25" and there is no shimmering with these.
$160 for all 4 BRAND NEW
Located in Rosemead, CA
I'm located in Los Angeles and no longer drive an rx8 so I can't take pictures but I've seen rx8's slammed on 19x8.5 and 19x9.5 what makes you think a 1 inch spacer isn't going to fit on a stock 18x8 wheel?
I bought 25MM for my stockers. there is also a member here with 25MM spacers on his gunmetal stockers and it looks sick. If these were hubcentric I would be all over it. I got what I thought was a sick deal on 25MM H&R hubcentric spacers and come to find out the bore size is too small
Just because it works on 19x9.5's doesn't meen it will work on stocks. It all depends on the offset of the 19x9.5's. These would be ok on stocks if your car isn't lowered at all. If it is you will have to roll your fenders somewhat to prevent rub when taking bumps.
25mm is not as extravagant as you would think. The center bores are 2.25" and will clear most import setups as for being hub centric as long as you center them before torquing there really is no difference. I've run enough of them on many cars and know they're quality adapters.
