Stance GR+ Coilovers!
Old Feb 7, 2009 | 03:02 PM
Race Roots's Avatar
Former Sponsor
We are now carrying Stance GR+ Coilovers!
MSRP: $1495 PM For RX-8 Club Discount!
GR+ is the Stance main flagship line of coilovers. Oversized diameter shocks allow large pistons for ultimate performance and response. 15-way adjustable damping allows the driver to tune the shocks for any conditions and handling characteristics. With huge range of adjustment that can be felt and seen, GR+ offers serious performance for all levels of drivers. GR+ coilovers are built with highest quality materials and tolerances to ensure durability and performance.
Key Features:
- Front Spring Rate: 9k
- Rear Spring Rate: 6k
- Pillowball Uppermount
- Cold Wound Linear Spring
- Inverted Monotube Shocks
- Aluminum Collars & Upper Mounts
- Height Adjustable Lower Bracket
- Comes with a pair of Adjustment **** Extensions
- Optional 6k Spring Available at Request
In regards to more information on Stance:
1. Standard setup is now 9kg/6kg as listed on Stance website with the 200mm springs, the longer ones, for the rear.
2. Stance adjuster on GR+ and Pros is Single Adjustable REBOUND. Rebound is what's always adjusted. Compression should remain pretty constant. Tokico illuminas and Dspecs however adjust both damping curves simultaneously. KYB AGX and Koni are all single Rebound adjustable.
Old Feb 9, 2009 | 11:56 AM
Race Roots's Avatar
Former Sponsor
Thanks for the order Ikon, you set will be sent with your exhaust
Old Feb 9, 2009 | 12:17 PM
Greenblurr93's Avatar
Sotally Tober
How many of these do you have on hand??
Old Feb 9, 2009 | 07:22 PM
Race Roots's Avatar
Former Sponsor
1 set
You should know better
Old Feb 12, 2009 | 04:41 PM
What is the 8-club discount?
Old Feb 12, 2009 | 05:43 PM
T-ReX-8's Avatar
Stormtrooper RX8??
Very nice.
Bizump!
Old Apr 14, 2009 | 08:46 AM
MilesJ's Avatar
Can you post up some pics of the actual coilovers? Also, these are single adjustable right. Does the adjuster affect rebound only or rebound and compression together?
Old Apr 15, 2009 | 02:38 PM
Race Roots's Avatar
Former Sponsor
Old Apr 23, 2009 | 09:55 PM
Race Roots's Avatar
Former Sponsor
Next week these bad boys will be available again!
Old Apr 23, 2009 | 09:58 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
so tempting
Old May 26, 2009 | 11:11 AM
Race Roots's Avatar
Former Sponsor
All back orders shipped!
Old Jun 23, 2009 | 09:53 AM
RX8YA's Avatar
WAH WAH WAH
Any available now?
Old Jun 23, 2009 | 10:21 AM
Race Roots's Avatar
Former Sponsor
Yes! Available for shipping now.
Old Jun 23, 2009 | 11:30 PM
Race Roots's Avatar
Former Sponsor
Updated First Post with Information and changes from Stance!
Old Jun 24, 2009 | 04:24 PM
trustbuddy's Avatar
Originally Posted by Fluid Motorsports
ahhh... now i see why there was a spike in the number of views of this picture from my photobucket account...
good to know it's put in good use.
Fluid, even though you didn't ask me if you can use my picture, I APPROVE~!
I know your a good guy.
Old Jun 25, 2009 | 08:32 AM
Race Roots's Avatar
Former Sponsor
Such a pretty picture
Old Jun 29, 2009 | 07:21 AM
sauceyI986's Avatar
about how low can u drop the car down with these
Old Jun 29, 2009 | 10:43 AM
TopGear8's Avatar
mkuhnracing.com
Just installed these on Friday. You can drop the car up to 3 inches.
Old Jun 30, 2009 | 11:02 PM
sharkpah's Avatar
nice
let me see some picture mike!
Old Jun 30, 2009 | 11:06 PM
TopGear8's Avatar
mkuhnracing.com
^Looks the same as it did before, I kept it at the same ride height I used on my Megans.
Old Jul 3, 2009 | 08:55 PM
Endless Rotaries's Avatar
Hope this helps:
Alright so I made a video of how to setup the REAR RX8 coilovers. They have an unconventional design so I took the initiative to give you the basics.
Step 1: Reset all spring preloads
Step 2: Install on car
Step 3: Put car on ground and take baseline measurements
Step 4: Determine where you want the car to sit.
i.e. If car is ground to fender at 25" and you want 26", please note the 1" Difference or whatever the delta is on each corner.
Step 5: Put car back in air. Adjust front coilover lower brackets with their respective "delta" value. Meaning up or down 1", whichever direction. Since we're raising the car the bracket goes in a direction to "lengthen" the unit.
VIDEO WILL HELP YOU HERE" STEP 6
Step 6: REAR COILS: remove lower bolt so that the coilover has some room to drop the spring. you might need to remove a suspension arm to gain clearance. Remove spring, then loosen the small inner collar that remains so you can adjust the ride height/inner tube by 1".
Step 7: Once bracket is position and locked into place you can install the spring, washer, spring perch, and locking collar. Add the preload back to the spring.
HERE'S THE PROBLEM PEOPLE HAD AND NOW YOU MIGHT BE ABLE TO VISUALIZE IT:
1. WHEN YOU RAISE OR LENGTHEN THE REAR DAMPER, IT REMOVES PRELOAD FROM THE SPRING SO YOU NEED TO ADD PRELOAD BACK TO IT.
2. WHEN YOU LOWER OR SHORTEN THE REAR DAMPER, IT ADDS PRELOAD TO THE SPRING SO YOU NEED TO LOOSEN IT BACK TO NORMAL PRELOAD.
BY RULE OF THUMB FOR THE REAR YOU SHOULD ALWAYS REMOVE PRELOAD OR SPRING ALTOGETHER BEFORE MAKING THE HEIGHT ADJUSTMENTS. THEN BUT THE SPRING BACK OR ADD PRELOAD BACK AFTERWARDS.
Rishie
Old Jul 4, 2009 | 12:24 AM
NoOdLe BoY's Avatar
thanks for the info and vid. been thinking about purchasing these but not sure yet.
Old Jul 4, 2009 | 12:25 AM
TopGear8's Avatar
mkuhnracing.com
^You will like them. But if you get the same coilovers, and wheels as me, I don't know how I would feel about that
Old Jul 4, 2009 | 06:59 AM
RX8YA's Avatar
WAH WAH WAH
Mine should be here Friday!! I cant wait..^Topgear8 no review yet hope the event went well.
Old Jul 4, 2009 | 10:31 AM
TopGear8's Avatar
mkuhnracing.com
^Was not able to get an alignment before the event, so I still can't give a serious review on them.
