{ FS } Fat Cat Motorsports Coilovers
Old 06-07-2019, 08:49 PM
WastedAccounts's Avatar
FL Fat Cat Motorsports Coilovers
Category: Steering & Suspension
Price: $3000
Fat Cat Motorsports coil overs for RX8 or NC Miata
Bilstein HDs modified with every option he offered at the time
Ripple reducer
Kerb Blow Off
Bumpstop tuning
Dyno'd and pressurized for each corner specifically.
Front shocks are from RX8/NC (they're the same)
Rear shocks are from NC Miata to take advantage of the shorter stroke
Eibach springs
550lbs front
425lbs rear
Height adjustable spring perches and helper springs
Spring rates can be tuned up or down 100lbs without needing a revalve on the shocks
Not even 1000 miles on
These were smoother and more supple on the street then the factory setup even at these high spring rates.
Ask me anything. Shaikh holds personal consultations with each client to make sure they get what they want. These were perfect. I know longer have the car and was planning on moving them into an NC Miata project but ended up going a different direction.
Note: NC Miata will need a different rear top hat then the RX8 uses.
Asking $3k
Corner weights of the car I provided when I ordered these.
These are without me in the car
LF837 RF790 F1627
LR670 RR695 R1365
Total 2992
Corner weight pic was after I installed the FCM Coil overs and had the cars corner weights adjusted by a local shop
I ran these with stock sway bars. I was told by FCM that I should be using an NC though.
WastedAccounts is offline
Old 07-16-2019, 06:45 PM
To the top. Message me if you interested.
swoope
Series II Wheels, Tires, Brakes & Suspension
10-18-2019 03:42 PM
nisarnadaf
General Automotive
10-03-2011 07:35 AM
atanesyan
05-31-2011 04:13 PM
Quick Reply: { FS } Fat Cat Motorsports Coilovers
