{ FS } Racing Beat Software and ECU - 2004-2008
Old 12-03-2010, 04:40 PM
Nature vs. Nurture
ganseg's Avatar
Category: Engine - Power Adders
Price: $350
Location (US State/Canada/Int): MN
Price Drop!
Racing Beat V2 flash on a 2004 ecu 6 spd. This will work on all series 1 rx8's as it has been programmed to work around the immobilizer. I used it on my 2005, perfect if you need an ecu or want to be able to swap it in without any downtime. The RB software leans out the mixture above 4,500 rpm and lowers the fan on temp to keep your car cooler. This ECU can be swapped in a 1/2 hour.
Old 12-03-2010, 06:50 PM
Nature vs. Nurture
ganseg's Avatar
Before and after dyno:
This is an 11.7 hp gain at 8,800 rpm with RB software and a catless midpipe (also for sale). The redline is raised to 9,300 to make use of this.
Old 12-16-2010, 11:00 PM
Rotaman's Avatar
NZ
Hi There
I'm interested in your Racing Beat modified PCM, would you be interested in shipping internationally, specifically to New Zealand? If so what would be the shipping cost?
Also could you let me know what the PCM ID is, which should be stamped/sticker on the PCM box.
Obviously this PCM could or should be able to be flash tuned with a Cobb accessport?
You can email me if you like, - miura@ihug.co.nz
Thanks, any info will be much appreciated.
Regards
Rotaman
Old 12-17-2010, 05:55 AM
Nature vs. Nurture
ganseg's Avatar
As you can see from the dyno, the ECU and RB software worked (the higher redline proves the RB software is on there). The numbers are faded - see my best guess in the pictures below. It clearly says N3H6 across the top. The second part in black background has a row has Eor F, then G and a third letter that could be I, H or N. The second row with the black background is N3H6 78 88??? Under that is white background 5-279700-???. Under the bar code is *000739J*
I also have what looks like an inventory tag which had a VIN the same as what was written on the ECU cover. Here is the text:
Stock # 71135 Model Mazda RX8
IC # U/R Engine Brain Box
Description
Comments:
YR 2004
VIN: JM1FE173040107413
Old 12-17-2010, 02:14 PM
Rotaman's Avatar
Hi There
Why are you selling this PCM?
Also could you let me know what the PCM ID is on the PCM that you are running in your car now? The reason I'm after this info, is just so I can do a comparison of what the Racing Beat PCM ID is compared to what is in your car now.
One other request, would it be possible for you to take a photo of the RB PCM top cover with the PCM ID on it and maybe one of the one in your car now and email that to me.
Sorry to be a pain in the ****, but if I'm going to look at buying this I want make sure it is going to work in my JDM RX8.
Regards
Rotaman
Old 12-17-2010, 03:15 PM
Nature vs. Nurture
ganseg's Avatar
I didn't get the gains where I wanted them. The labels are hard to read so I wrote out a note of the best I could tell.
Here is my stock ecu in my 2005 MT:
Old 12-18-2010, 02:20 PM
Rotaman's Avatar
Hi There
I have emailed Racing Beat and are waiting a reply from them, I would like there opinion on whether they think this would work with a JDM RX8.
I will get back to you once I have heard back from them.
Regards
Rotaman
Old 12-20-2010, 04:50 AM
04 NORDIC GREEN RX8
willnordacgreen1211's Avatar
^ JDM rx8? lulz glws
Old 12-25-2010, 08:34 PM
Nature vs. Nurture
ganseg's Avatar
still available.
Old 12-25-2010, 09:03 PM
StealthTL's Avatar
Good price!
S
Old 01-04-2011, 10:43 AM
Nature vs. Nurture
ganseg's Avatar
Tothetop
Old 01-07-2011, 07:34 PM
CVale127's Avatar
ganseg....without the catless midpipe what do you think would be the hp gain for an 8 with stock exhaust system ? Also, would this ECU be compatible with a Cobb Accessport ?
Old 01-07-2011, 10:03 PM
Nature vs. Nurture
ganseg's Avatar
I can only say that Racing Beat told me that the V2 software would work fine with a cat. I guess your best reference is their website. The ECU will be compatible with the Cobb Accessport. This is a good way to get RB software without the downtime of shipping your ECU.
Old 01-08-2011, 11:28 AM
CVale127's Avatar
Does that mean it didn't work well for you ?? By looking at the dyno sheets tho it looks like you had a pretty good gain. I'm confused.
Old 01-08-2011, 12:14 PM
Nature vs. Nurture
ganseg's Avatar
I wanted gains from 6-8k. I already have a different mod to give me the lower fan-on temperatures.
Old 01-14-2011, 09:48 PM
Nature vs. Nurture
ganseg's Avatar
Price drop!
Old 01-14-2011, 09:51 PM
StealthTL's Avatar
Even more gooder price!
Old 04-20-2011, 06:21 PM
Nature vs. Nurture
ganseg's Avatar
Here is what the previous owner wrote (dedicated race car with CAI and straight exhaust): "I ran the rb flash v2 and saw .90-.91 lamda (13.3 afr)with timing up to 34 degrees wot." As you can see from my dyno, my afr wasn't quite that lean, but each car has its differences. Also, I only have a K&N dropin for the track - not a CAI.
Old 04-20-2011, 06:34 PM
terch1's Avatar
I have the race flash installed on my PCM and love it. Great price!
02-27-2020 08:39 AM
Ovr-9000
04-07-2016 11:19 PM
r-enzyme
10-01-2015 01:27 AM
Trekk
12
09-25-2015 03:08 PM
cgrichie
09-19-2015 07:03 PM
Quick Reply: { FS } Racing Beat Software and ECU - 2004-2008
