{WTB} Tools and used parts for engine rebuild
Old 05-17-2018, 05:48 PM
Project Seca
Ricky SE3P's Avatar
CA Tools and used parts for engine rebuild
As the title reads I’m in search of a few secondhand tools and parts needed tear down my motor and to be used on the temporary motor that will be installed in my 8 while I do a proper build on my current low-compression engine. I will update this list as I source the items on it, or to add additional items.
  • Engine stand adapter
  • 54mm flywheel socket
  • Flywheel stopper
  • Low mileage clutch kit (if advised as acceptable, I willreuse the pressure plate and put a new clutch disc. I will be installing a NEWrelease bearing no matter what route I go.)
Ricky SE3P is offline
Old 05-17-2018, 07:58 PM
Track Car Obsession's Avatar
I have an almost brand new clutch kit if you are interested. Previous owner just had it installed and the secondary air pumped shorted and took out the ecu so he didnt want to put any more money into the car. I did a full drivetrain swap, so the clutch has around 50 miles on it. I'll take $50 for it, but I don't know what shipping will be to CA. I can get pictures tomorrow if you want them.
Track Car Obsession is offline
Old 05-17-2018, 08:16 PM
Project Seca
Ricky SE3P's Avatar
Interested, sending you a PM
Old 05-21-2018, 01:09 PM
Project Seca
Ricky SE3P's Avatar
got my hands on a flywheel socket, crossed that off the list
Old 06-19-2018, 06:10 PM
Project Seca
Ricky SE3P's Avatar
list updated; still hunting down a stand adapter and a flywheel stopper
Old 06-29-2018, 04:54 PM
Project Seca
Ricky SE3P's Avatar
Decided to just purchase the stand adapter and flywheel stopper from mazdatrix. Will update with parts needed as soon as I open the engine I bought to rebuild.
Old 09-14-2018, 07:33 AM
Prescription_RX's Avatar
I Have a good gasket set that you will need for the rebuild, It has all the metal and rubber gaskets that go to all of the manifolds and pieces.
Prescription_RX is offline
Chris
12-20-2014 08:57 AM
shainiac
03-23-2013 03:10 PM
ZOOMBY
Australia/New Zealand For Sale/Wanted
27
11-10-2012 02:47 AM
Vlaze
07-30-2012 09:13 AM
wb rx-8
04-28-2010 07:22 PM
Quick Reply: {WTB} Tools and used parts for engine rebuild
