{ FS } 2004 rx8
2004 rx8
I have a 2004 rx8 up for sale now. It is partly gutted as I was going to autocross it. Things changed. I am getting rid of cars I don't want. I will take no less than 1200 for it.
The good:
Has only driver's seat.
Radio works and stock, but only when interior is warm inside...I don't know why but sound doesn't work if it gets cool inside the car.
A/C works as I started it less than 2 weeks ago. Heat works well, too.
Nothing leaks.
The bad:
low compression, but starts and runs but will not restart hot.
driver's side window only goes down about quarter inch. Passenger side is fine.
chassis has 193,xxx miles.
Car is dark green with almost no rust. I have put 13,xxx miles on it despite the bad compression. I premix 1 quart of 2 stroke oil to a full tank. Trans is decent but 2nd is rough in higher rpm changes if you try to race it.
if interested, text me, don't call. 404-202-3881. I will answer any questions that I can. It will come with stock wheels. Good tread depth on the tires, too. It will not come with a battery unless you want to pay more for the car. I have a relatively new antigravity battery in it. If you want it, too, will be extra. Has upgraded rotors and hawk hp+ pads and stops very well. Not sure how much pad is left though. Text if interested.
thanks
The good:
Nothing leaks.
The bad:
thanks
rx-fish04
Jan 15, 2017 02:59 PM
rx-fish04
Dec 29, 2016 10:14 AM
twistedwankel
RX-8 Discussion
Dec 13, 2012 03:01 PM
