{ FS } Pettit Racing built engine (rew rotors) part out
Old May 2, 2019 | 02:00 PM
rotoryfan1991's Avatar
KY Pettit Racing built engine (rew rotors) part out
Category: Engine - Complete Motors
Location (US State/Canada/Int): KY
I just took apart the Pettit Racing built engine from my Rx8. The car was built by Pettit and also had their supercharger kit on it.
The engine was built to be better for boost. The engine used Rx7 Rew engine rotors to lower the compression ratio and also use the much stronger / taller rew apex seals.
In order to run these rotors in the engine they had to custom machine new grooves into the sides to accept the 3rd Rx8 oil scraper ring.
The sides of the rotors were also machined to lighten them and add more clearance.
The full rotating assembly was then balanced.
The engine also has Pettit Racing porting done to the irons.
REW rotors with aftermarket apex seals / all other seals / machined / includes counterweights / eccentric shaft etc (Full rotating assembly) - $950
Rx8 engine irons ported by Pettit Racing ( All 3 irons ) - $500
This picture shows the size of the RX7 apex seals vs a new RX8 apex seal on bottom.
Old May 2, 2019 | 03:36 PM
Ricky SE3P's Avatar
Project Seca
PM sent..
Old Oct 23, 2020 | 01:24 AM
sapibuntinx's Avatar
interested with the rew rotor, is it still available? I wonder why it's being on sale, I thought it's good for boosted rene?
Old Oct 26, 2020 | 10:53 AM
the OP said these parts sold a long time ago, this thread needs to be closed
Old Oct 27, 2020 | 03:42 AM
ah, since we got team here, what do you think of this rotor combination with renesis team? is it really necessary & helps with the reliability when boosted?
EXE-UK
Dec 11, 2014 08:35 AM
chironwsc
Aug 30, 2008 02:37 AM
DOMINION
10
Sep 7, 2007 03:46 PM
Philip_SA
11
May 2, 2007 05:34 PM
rotarygod
May 2, 2004 08:02 PM
