Self Vented Hood with GT500 Hood Vent
Old Jun 30, 2015 | 08:08 AM
Originally Posted by FerociousP
I doubt I'll see a very big change just moving the battery, at least enough of a change to justify the cost... expecially when I have to buy the battery, mount it, then modify cabling.
Piece of cake and probably less cost compared to the hood vent, it sounds like the fun exercise concept lost it's twinkle
It probably would have been just as effective to put spacers between the hood and the rear hinges to raise the back end of it up ...
Old Aug 22, 2018 | 03:36 PM
Blue2010R3's Avatar
Interesting project. I thought about doing something similar but lost motivation/courage/time.
One thing you could do is buy a few USB barometers as this link describes:
Air Flow and Pressure Around Car
You could then plot out whether you actually have a low pressure area above your hood vent vis-a-vis your underhood pressure. (I imagine you'd want high pressure right in front of your radiator and low pressure above your vent to aid heat extraction).
As I understand it, the front half of the hood typically has the lowest pressure (see http://flyinmiata.com/tech/images/NC-hood-pressures.gif), but from your experience it seems like there's a point where the vent will be in front of the hood and a pressure differential will actually cause air to bypass the radiator. Hard to tell from the pics, but do you think this ebay hood has the vent too far forward? https://www.ebay.com/i/300752073566?chn=ps
Keep up the good work!
Old Aug 22, 2018 | 04:01 PM
a whole thread dedicated to vented hoods if people want more ideas: https://www.rx8club.com/rx-8-discuss...amples-263569/
only posting it here since that thread is newer than this one.
nvrfalter
General Automotive
39
Nov 2, 2009 06:52 PM
WVBoosted8
RX-8 Multimedia/Photo Gallery
30
Feb 11, 2009 10:21 AM
nuke0907
75
May 24, 2008 01:33 AM
VividRacing.com
157
Nov 12, 2004 04:21 PM
VWjet
RX-8 Discussion
15
Oct 8, 2002 08:09 PM
