Far East/Asia Serving the Far East
Lambo Door Preview
Old Dec 16, 2005 | 10:23 AM
Originally Posted by GrRx8MaZdA
^They are lambo style as you said..Not lambo doors!!LOL
But this is the only kit with 90degrees...I love them!!
There are actually two companies that I am aware of that are making kits that do 90° - GT Factory (which is what I used) and WingDoors.
Old Dec 16, 2005 | 10:36 AM
GrRx8MaZdA's Avatar
90% Carbon-100% Power
I don't know wingdoors sorry mate if i am wrong...
Old Dec 16, 2005 | 11:45 AM
Outlaws eXtreme's Avatar
2010 Prius - Miss the 8
The doors that would look pretty interesting and different would be the A-pillar type doors... like the one on the Iosis prototype car. Most of the new "show" cars in Cali are using them instead of VD.
Old Dec 16, 2005 | 12:01 PM
As a modification, they would be structurally pretty unsound.
The frame around the window is not strong enough to support the door in the long term, not to mention the bulk of a hinge being installed there.
Show cars don't have to be driven every day.
Now in a production model, these things can be taken into consideration when designing the door, but it is still a difficult proposition.
Old Dec 20, 2005 | 02:37 AM
kenji_jim's Avatar
That at Frankie's Shop right?
I rem he mentioned that he was doing the Lambo doors for a few customer
Old Dec 20, 2005 | 08:15 AM
morganoh's Avatar
Yes...
Old May 3, 2006 | 09:31 AM
artistknownasbush's Avatar
artistknownasbush
hi, cant seem to find mazdaparts; how can i obtain a set? please help thanks
Old May 3, 2006 | 09:34 AM
yiksing's Avatar
the giant tastetickles
How safe are lambo doors in comparison with stock in case of direct side impact?
Old May 3, 2006 | 10:16 AM
morganoh's Avatar
Can buy it from www.lsddoors.de or u can buy it in Singapore cos they have a dealer in Singapore
LSD is the best vertical door kit manufacture , all their door kits has crash test certifications.
Old May 3, 2006 | 10:18 AM
morganoh's Avatar
The vertical door kit hinge is much much stronger and also heavier than the original hinge.
Old May 3, 2006 | 08:38 PM
yiksing's Avatar
I don't doubt the door being stronger but how about the joint where the door is supported.
Old May 3, 2006 | 11:48 PM
morganoh's Avatar
The LSD door kit is a direct bolt on kit, that uses the original holes that the origianl hinge used
Old May 3, 2006 | 11:52 PM
morganoh's Avatar
The vertical door kit in this thread is not an LSD kit, its a cheaper version
(40% cheaper) The LSD is much better and the best as u can adjust the LSD hinge in all dimensions in order for a perfect fit on the RX8 while the cheaper ones can't
I have the LSD door kit on my car and will post the some photos of the LSD door kit from my car in a few days time
Old May 4, 2006 | 12:31 AM
CruiseGuy's Avatar
Reminds me of the Sera Gulwing..
Doubt that the 8's door can be hinged on the top.. will be Very Very interesting..
Old May 4, 2006 | 04:58 AM
lohsk's Avatar
"Beng Your Ride"
Didn't I tell you LSD was the best. Lucky you install LSD.
Old May 4, 2006 | 09:17 AM
jmaluso's Avatar
Those doors are rediclous. Who would ruin their RX-8 with those ricer-boy doors...
- shakes head in disgust -
Old May 4, 2006 | 10:36 AM
ngkenny's Avatar
stock standard
you are rediclous
Old May 4, 2006 | 12:59 PM
yiksing's Avatar
There's an advantage to lambo doors: You don't have to open the door as wide to get out.
Old May 4, 2006 | 02:52 PM
jmaluso's Avatar
oops...I made a nice spelling error huh? Bad spellers of the world untie! :D
Originally Posted by ngkenny
you are rediclous
Old May 4, 2006 | 08:17 PM
lohsk's Avatar
"Beng Your Ride"
ha ha ha ...
Old May 5, 2006 | 04:23 PM
seymore15074's Avatar
Registered Pimp
Originally Posted by Tigster
I think the 90 makes much more sense, the 45's would get in the way when you enter or exit. I would be concerned with how hard the 90's would be to grab hold of and shut. But they do look very cool.
If either of them made total sense they would be stock...
Old May 5, 2006 | 04:26 PM
Registered Pimp
I figure they'd be the same, they're just nuts hinges...they open like a regular door just enough to then go up...
Old May 8, 2006 | 03:45 AM
Henry's Avatar
hey everyone i just got to know the price for the LSD $3300 before GST and install might get discount if it's a group buy
its takes 1 and half weeks upon Confirmation
Old May 8, 2006 | 06:03 AM
  #49
morganoh's Avatar
U need to find a good installer. That has experience in Vertical door kit and will do a very good job on the wiring.
Cos all wires got to be lengthen, and most people just use the twist and turn and tape up method. U must make sure the installer include an additional soldering step.
And most important, remove the batt power before doing anything , or the ECU will "blank out" and can't start the engine and will need to spend few hundreds of dollars to get it reset.
Old May 8, 2006 | 06:07 AM
Henry's Avatar
hey thanks morganoh for your advice. do you know of any good installer.
