Power to the windows after the key is off
Old Aug 28, 2003 | 08:42 PM
91vert's Avatar
OK.....I'm not really good about reading the owners manual from cover to cover, so forgive me if y'all already know about this.
I have had my car for about a month now, and I just now noticed tonight that the windows will still operate after the key is in the off position (or maybe I already had the key out??? )
Anyway....I know that there are other cars out there that have this "feature". I owned a Chrysler Sebring back in 1995 and that car did that so I am familiar with it. I just didn't know the 8 had this little convenience.
I don't know how many times in the summer I realize that I did not leave my windows cracked to let some of the heat out of the car while it sits parked until after I already have the engine shut off and the key out.
Just thought I'd share this little discovery in case you guys have not noticed it yet.
Old Aug 28, 2003 | 08:43 PM
Wing's Avatar
Yes the windows will work until you open one of the doors. There is probably a time limit like 45 secs as well.
Old Aug 29, 2003 | 11:35 AM
jtdwab's Avatar
I have always liked this feature in a car. My only problem is that I foget the window is still open until after I open the door. Power is cut at that point.
I have a slightly different question along the same lines. For the RX-8 you have to put the key in the ON position to use the windows and not the ACC position. Most cars I have used in the past have the windows on in the ACC position. I didn't place the car in the ON position unless I was staring the car. I have been told that leaving a car in the ON position when not running can be bad because the car is reading to start (fuel pump may be on, RX-8 air pump on, etc.) does it hurt the RX-8 to be in the ON position for a little while?
Thanks,
Old Aug 29, 2003 | 11:41 AM
8_wannabe's Avatar
Go baby!
Re: Power to the windows after the key is off
Also true for the sunroof and Homelink buttons. Nice feature. My wife's beemer, the homelink goes off when you turn off the car, a real nuisance when you want to open/close the garage door. Gotta put the key back in, turn to "on" position, ...
Old Aug 30, 2003 | 01:34 PM
OverLOAD's Avatar
Hyper Space RX-8 _,.-^'`
Strange, My 8 only lets me operate with windows/sunroof with the key in the on position.. no delay..
Old Sep 1, 2003 | 10:14 AM
RodsterinFL's Avatar
It functions right after you turn the key off and before you open a door.
Old Sep 1, 2003 | 11:04 AM
OverLOAD's Avatar
ok, checked it out, I do have about 45 seconds or so, to get the windows.. but The moonroof is off as soon as the engine is off. No delay.
Also, anyone notice how far the tilt button opens the roof? It opens mine only about 1"... I can get it open much further by using the slide button..
RevMeHarder
Jun 1, 2026 02:30 PM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
