Where the %#?+^* heck is all this heat coming from anyway?
Old Sep 2, 2006 | 07:55 PM
olddragger's Avatar
In a valant effort to show how utterly stupid I am I would like to ask the forum trolls where is all the heat coming from that ends up in the engine bay anyay? Yep probably the engine.
Ok more specific-- is it the the engine----is it the exhaust header---is it a combo of both--or is it secret infra red rays beamed at every rotory engine in the world from the other car manufactors?
Yall know I am drunk--right?
IF--most of the heat is coming from the header(As I suspect) or even if its just a good bit of heat from the header then why dont we have someone talanted(this excludes me) to fabricate a heat shield for the !@#(*&^) thing.
Header wrap has been discussed somewhat I know with mixed feelings but what about a heat shield? Yall have seen the survival blankets things places like summit sales or maybe I can get GranMA to quilt one for us.
Thoughts before I sober up.
olddragger
Old Sep 2, 2006 | 08:12 PM
BlueRenesis82's Avatar
Registered Tracker
lol Denny
Old Sep 2, 2006 | 08:24 PM
dillsrotary's Avatar
jersey fresh
haha, drunk threads make the weekend grand
Old Sep 2, 2006 | 08:25 PM
chr1s's Avatar
pwn*
hehe, yay for drunk entertainment!
Old Sep 2, 2006 | 09:58 PM
Easy_E1's Avatar
The heat is from the exhaust manifold and exhaust system. The engine is only going to heat up slightly above thermostat temp preset. That exhaust is the hottest I know of on a production car. I don't see why the Kevlar header wrap would not work to keep the engine compartment cooler. I was considering doing all the way back to the Y-Pipe. This would keep the underside of the car a bit cooler (and the cup holder).It's also suppose to help scavenge the exhaust down the pipe a bit better keeping the exhaust from cooling to soon and keeping the velocity of it up thus evacuating the exhaust faster and more efficiently. When I get the new exhaust system I think I will do that.
Old Sep 2, 2006 | 10:57 PM
alnielsen's Avatar
I bought header wrap for my RX7 and never put it on. I was told that it trapped moisture and caused corrosion. This may not be a problem on a street car which is run regularly.
Old Sep 2, 2006 | 11:30 PM
it's mostly from the radiator/fan discharge
Easy_E1's Avatar
I have heard of that also but I live in Arizona and we don't have humidity and when it does rain it is dry in an hour. I don't think I would worry about rust. Also the exhaust is Stainless Steel. Plus the temp this exhaust obtains would dry it out in a very short time(seconds) lol, if it could even get wet,,kinda like drops of water on red hot steel,water will just bounce off.
You could always paint the exhaust with High Heat Paint to seal it up.
I personaly won't worry about moisture.
Old Sep 2, 2006 | 11:47 PM
Keef's Avatar
the shit starter
It would be an interesting idea to fabricate headers with a seperate radiator... haha, ya right... or is that a stupid idea?
Old Sep 3, 2006 | 12:23 AM
alnielsen's Avatar
That wouldn't work well. The heat in the header isn't the problem and is accually good. It's the fact that it radiates into the engine bay is what isn't desireable.
Old Sep 3, 2006 | 06:26 AM
olddragger's Avatar
Dang---I spel better when I am Drunk
OK-- on the wraps --if anyone does that make sure you dont get too close to the o2 sensors--they get too hot and there goes your beer money.
I think I will take a roll of aluminum foil and isolate the header from the engine bay(short term) drive a little and just see what happens. Hell if that deosnt do anything then i just may leave it their and cook lunch on it. May as well get some use out of it. After that i will make a pyramid out of it and put it on my head to get egyptian rays to help with this moonshine hangover
olddragger
Old Sep 3, 2006 | 02:01 PM
Brettus's Avatar
Boosted Kiwi
what we really need is one of these - I'm sure it will solve the problem.
http://kalecoauto.com/index.php?main...products_id=35
Old Sep 3, 2006 | 02:55 PM
zaglo6204's Avatar
mine's better
mmmmm i love asbestos
Old Sep 3, 2006 | 03:39 PM
Trekk's Avatar
Goat rider
Can anyone explain how the side vents work? I dont see under the hood any place they hook to.
Old Sep 3, 2006 | 05:19 PM
unreal89's Avatar
I don't mind pistons
the side vents are for show.. they do nothing
Old Sep 3, 2006 | 05:58 PM
olddragger's Avatar
no there is actually a little flow there. From the oil coolers back I think. BUT you mentioned one thing I am thinking about--making them more useful --shouldnt be hard to do? Team says the rad/fans give out a lot--probably very correct,--so shielding the exhaust header(with blanket not wrap) and making the side vents more functional in moving the heat out of the engine bay? Maybe some glowing red lights behind the side vents also that activate when you race your motor at the stop light?
HMMMMMMM!
Old Sep 3, 2006 | 06:06 PM
Trekk's Avatar
Goat rider
HMMMMMMM!
PFfftttttttttttttttt!!! Thats so noob. You gotta go get a NOS kit and dont hook it to the motor. just shoot leet smoke out of the side vents!
Old Sep 3, 2006 | 06:31 PM
Trekk's Avatar
Goat rider
re
Woohoo rain finally stopped.. for about 2min... anyways the side vents do work! and its not working off the oil coolers. I wanna try to cut those holes bigger/
and this is what i did to my oil coolers.
Old Sep 6, 2006 | 05:04 AM
ph0tic's Avatar
Search the !@#$ forum!!!!
https://www.rx8club.com/rx-8-multimedia-photo-gallery-6/thermographic-pics-83423/
Hehe, eh just kidden dude. But those pictures should be able to help you pinpoint *exactly* where the heat comes from.
And as for insulation. I have been dying to find an application for this: www.aspenaerogel.com . Best insulation around.
Old Sep 6, 2006 | 07:41 PM
rxeightr's Avatar
M0D Squad -charter member
I can vouch that the header pipe insulation works!
At least on my '64 Stingray it does. I used to have vapor lock because of the underhood temps, and since I wrapped the headers there has been no further issues.
That was back in 1990, and still have the same headers, so I doubt the corrosion factor is an issue.
Old Sep 6, 2006 | 08:17 PM
Trekk's Avatar
Goat rider
I had header wrap on a set of DC headers for about 2 years. I took it off to sell them and all the had was sort of a burn mark of cloth pattern, but other then that they were in great shape.
Old Sep 7, 2006 | 02:34 PM
Trekk it looks like you have reversed the problem for oil screens.
Now your going to get rocks from the tires making a hole in the cooler.
Ever thought about putting a black plastic screen mesh on the inside of the well?
Old Sep 7, 2006 | 02:42 PM
Mandy's Avatar
<3
I'm so damn hot, my car feels it!
Old Sep 7, 2006 | 03:03 PM
Trekk's Avatar
Goat rider
Rocks dont fly that way.. unless your going backwords.. Anyways, you might not see it all that well but those cuts are still under the plastic edge that pops out.
Even if a rock did manage to fly off it would hit the over hang.
And yes I plan on making a full screan back side soon.
Old Sep 13, 2006 | 11:11 AM
Raptor75's Avatar
I believe these guys also sell refrigerator heaters, keeps that cold refridgerator nice and warm.
