Mazdaspeed CAI And Dual Exhaust Sound Clips
Old Aug 12, 2006 | 06:38 PM
jdzoom8's Avatar
I decided to take some clips of my Mazdaspeed Dual Sport Exhuast and Mazdaspeed CAI for viewing. Enjoy.
http://media.putfile.com/2004-Mazda-...-Sport-Exhaust
http://media.putfile.com/2004-Mazda-...old-Air-Intake
Old Aug 12, 2006 | 07:16 PM
painter1's Avatar
If its notBLACK its wack
Yo abbid, I use to love that freakin' game!!! I would rip the guns off the board and shoot the little metal ***** at my friends!!!
Old Sep 3, 2006 | 10:34 PM
CKay's Avatar
Sounds nice, can you feel a power gain
Old Sep 3, 2006 | 10:51 PM
NgoRX8's Avatar
intake sounds pretty tight.
Old Sep 3, 2006 | 11:28 PM
Tirminyl's Avatar
Listen to Zoom44
Cool, you need to get an in-car vid with it under load.
Old Sep 3, 2006 | 11:34 PM
mysql101's Avatar
you have the same annoying high pitched squeal from your intake that I do. I wish I could make it go away.
Old Sep 5, 2006 | 09:03 PM
success07's Avatar
I'm Kind of a Big Deal
I thought that noise was from the microphone on the camera?
Does everyone have that high pitch sound w.r.t. this intake?
Old Sep 5, 2006 | 09:12 PM
mysql101's Avatar
here's with revi intake + ram air duct:
http://video.google.com/videoplay?do...52599346&hl=en
Look at 1:30 mins in.
Now the same car, but with a turbo:
http://video.google.com/videoplay?do...56419041&hl=en
Look at 0:20 secs in...
I never noticed it with the stock intake.
The sound goes away completely if you toss a rag over the intake.
Old Sep 5, 2006 | 09:13 PM
mysql101's Avatar
oh, also have to mention, the sound isn't always there. I've started it up and had no high pitch sound... drove the car around, came back home and then noticed it.
Old Sep 7, 2006 | 02:26 PM
mysql101's Avatar
For some reason this is the first time I've read this TSB.... I think it's exactly the issue being described.
WHINE OR SQUEAL NOISE FROM ENGINE AT IDLE
Applicable Models
Model Starting S/N Ending S/N
2004 RX8 00000000 ZZZZZZZZ
Some customers may complain of a high-pitched whine or squeal noise from
the engine at an idle. The noise can be eliminated by raising the engine
RPM slightly above idle. This is most likely caused by the primary port
jet air nozzles and / or the metering oil pump air ports. The jet air
nozzles are located in the primary port of each rotor. The jet air flow
is acheived by using air flow from an area prior to the throttle plate.
The metering oil injection nozzles also use this airflow prior to the
throttle plate to assist oil flow into the engine.
This creates a metered vacuum leak into the engine and may cause a high
pitched whine at idle.
This noise is considered to be a normal characteristic of the RENESIS
rotary engine. Use the procedure outlined in the repair instructions
to confirm noise is from the jet air or metering oil pump nozzles.
1.Confirm noise.
2.Remove engine cover.
3.Locate both air supply hoses for jet air nozzles and metering oil pump
nozzles. Hoses are attached to the air duct located between the MAF
and throttle body. Disregard hose that attaches to the oil filler tube
4.Confirm noise is caused by jet air or metering oil pump nozzles by
temporarily pinching off air supply hoses using pliers.
5.No repairs should be attempted if noise is reduced or eliminated.
just1jack
Sep 9, 2015 04:45 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
