voltage / current / resistor question
Old Aug 23, 2003 | 03:46 AM
TerenceT's Avatar
voltage equals current time resistance
V = I R
so i am going to get some LEDs for interior lighting that are
1.7vdc to 2.2 vdc
car voltage is 14 vdc to 12 vdc
so
(14vdc - 1.95vdc) / .035 = 344.3 ohms
Old Aug 23, 2003 | 11:20 PM
ozbot87's Avatar
Yup.
BTW, what kind of LEDs are you getting? (Electrical Engineer here, so you can give me detailed info about them. :D )
Old Aug 24, 2003 | 02:23 AM
TerenceT's Avatar
let's look at my shopping list...
interior dome light, front(2) and back(2), and passanger foot well (2)
10 red LEDs 2200mcd, 5mm, clear, 45 degree, 1.7-2.2 vcd, 20ma
exterior mirrors bottom, going to tap the door light, so they'll come on when i hit the remote
2 yellow, 1200mcd, 5mm, clear, 45 degree, 1.7-2.2 vcd, 20ma
Misc
1/2 watt, flame proof 10 ohm resistors
1/2 watt, flame proof 330 ohm resistors
was going to get diodes but give up finding them
Old Aug 24, 2003 | 02:31 AM
TerenceT's Avatar
Misc
Old Aug 24, 2003 | 03:04 AM
ozbot87's Avatar
Good place to get parts such as diodes are:
Digi-Key.com
Or if you are a student, you can try to get samples from:
fairchildsemi.com
lite-on.com.tw
There are other LED manufacturers out there who might give you samples depending on the field of work you are in.
Hope this helps.
Old Aug 24, 2003 | 03:13 AM
TerenceT's Avatar
thanks man
i'll keep the links but from partsexpress.com
the bill comes out to be 10 bucks plus shipping
note to others:
LEDs are not as expensive as people might think!
Old Aug 24, 2003 | 03:14 AM
Doctorr's Avatar
Ricer is Nicer.....
Cool LEDs.......
Just bought 50 of the little b*ggers off ebay, for the footwell project......
12,000mcd.......SHOULD be bright enough......
Not very good with the cut&paste stuff, but the item # was 2550748679......also explains why I bought 50, when the lot size was 25......hit the 'buy now' button twice!.....DOH!
doc
Old Aug 24, 2003 | 03:21 AM
TerenceT's Avatar
the one you bought are very very bright!!
and focus too, only 6 degree
you'll be able to see if you date shave her legs!!! thru her panty hose!!1
Old Aug 24, 2003 | 03:26 AM
Doctorr's Avatar
Ricer is Nicer.....
Cool Resistors..........
I think your math is fine - 330 Ohms will be perfect.
You should consider bundling a few together, since they are so small, and the mirror is a long way from the ground.....
Keep us posted!
doc
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
TJSiegrist
Sep 10, 2015 09:29 AM
Rupanrx
Sep 4, 2015 06:44 AM
