HKS Sparkplugs
Old Jun 25, 2006 | 06:33 PM
HKS Sparkplugs
http://www.hksusa.com/products/?id=730
Just wondering,it saids for Rotary Applications, but has anybody here tried them before ?
Old Jun 25, 2006 | 11:24 PM
FE3P's Avatar
NO PSTNZ
These plugs were designed for 86-95 RX7's. Unfortunately, they will not work on the RX8. I've heard that HKS is considering making a specific RX8 Super Fire Plug!
Old Jun 25, 2006 | 11:42 PM
DOMINION's Avatar
I don't buy Kool-Aid
They will not work on the RX-8? Someone on here is useing RX-7 plugs??? I think it was Abbid or someone.
Old Jun 26, 2006 | 12:28 AM
well it saids its for "Rotary Applications"
We have Rotary, right ?
Someone IS using rx7 plugs, I remember RG said its ok to use 7 plugs in 8s. Actually u know what, I wonder what will happen if I put these plugs into my 8.
9 leading
9 trailing
it wont "blow" my Renesis I think. what you guys think? should I be the "brave" dude and give it a shot ? :O
Old Jun 26, 2006 | 10:12 AM
FE3P's Avatar
NO PSTNZ
I thought there was an issue with the length of the plugs being too long for the Renesis??
Old Jun 26, 2006 | 12:04 PM
rotarygod's Avatar
Since the casting thickness for the spark plugs is the same between the Renesis and other rotaries, I don't see why there would be an issue. On RX-7's I actually remove the spacer washer from the plugs to get the plugs right up against (but not touching) the chamber!!!
The best, most reliable plugs I have found to use in rotaries, including the Renesis, is the RX-7 plugs. BUR-7EQ and BUR-9EQ. If you must have platinum, add the letter "P" to the end of that number. They are less than $2 additional per plug for platinum and the standard plug is only a few bucks itself. Don't waste your time with the HKS, Greddy, etc plugs. Only buy the NGK plugs. You can get them at O'Reilly. Don't even use the Nippondenso plugs that Autozone sells. They don't last as long.
Old Jun 26, 2006 | 08:22 PM
I want to try some HKS plugs, I dont think they made those plugs probably just a re-brand. but I still wanna try some first.
Thx for the Advise RG, Im going to get some 7 plugs after I try some expensive ones.
Old Jun 26, 2006 | 11:15 PM
poorman's Avatar
So RG, are you saying the BUR-7EQ and 9EQ are better than the RE7CL and 8BT?
Or are they preaty much the same?
As it stands the RE's are 2x as much as the BUR's.
Old Jun 26, 2006 | 11:49 PM
mkl22's Avatar
do we need extra shims when using BUR-7EQ and BUR-9EQ for RX8? or it is just plug and play.
Old Jun 27, 2006 | 12:06 AM
rotarygod's Avatar
Just install them like you would any other plug. Scott uses them on his turbo RX-8's. You won't notice a difference in performance but your wallet will thank you. They are totally different looking plugs from the stock ones.
Old Jun 27, 2006 | 01:30 PM
If I use 7's plugs, will my engine flood easier?
cuz I thought that Mazda changed the leading plug to something else ?
(oh btw, what's 8's stock plug made out of ? is it even platium?)
Old Jun 27, 2006 | 01:38 PM
rotarygod's Avatar
I think the stock ones are Iridium. I'm not sure. Whatever they're made of, they aren't any better than the RX-7 plugs.
I'm just not one to believe that one plug is responsible for flooding engines. That's a tuning issue combined with the fact that the ignition system as a whole just plain sucks. Then you've got the original starter. What a slow turning piece. There are many things that contribute to flooding issues but I'm not willing to claim one heat range different on spark plugs is going to do it. That shouldn't even matter.
Old Jul 6, 2006 | 07:18 AM
crimson-rain's Avatar
hey abbid, was your starter and battery changed? I had to have mine changed earlier this year cause she wasn't even trying to start. Flatbedded and carted to dealer for replacement (that day sucked).
If what guys say is true, I think I'm going to pick up a set. I'm about due for some more plugs.
Old Jul 6, 2006 | 09:04 AM
If the FD's stock plug works ..... and it only cost a few bucks each ...
why the hell are they selling 8 plugs at like 30-40 bucks each!?
thats a rip off.
Old Jul 6, 2006 | 11:44 AM
Brice-RX8's Avatar
thats a rip off.
Because the stock plugs are in fact iridium, and they (NGK and/or Denso) feel they can get that kind of money for these plugs. The way it sounds from Rotorygod though, the iridium isn't really worth it in the end.
Hey RG, if the factory iridium are supposibly good for 35k miles (per Mazda), how long have you run or going to run the 7's plugs? All based on a N/A 8 of course.
Old Jul 6, 2006 | 12:56 PM
rotarygod's Avatar
It depends how hard you drive. There's no reason why they can't go 35K.
Old Jul 6, 2006 | 02:45 PM
icyur2's Avatar
Shonen
Go to http://www.ngk.com/
Based on their website, our plugs cost $19.95/plug + s/h..so..way below $35/plug...for 2 Trailing plugs & Lead plugs, that totals to $80 + s/h..add that to how often we change our plugs..that is like $26/yr if you do 10k/yr and change it out every 30k..
Old Jul 6, 2006 | 11:29 PM
KJ238's Avatar
Air + Fuel + Spark = Boom
The Stock plugs are NGK Iridiums...
I'm using a set of NGK Racing Comp Plugs 9L10T if you are interested...
Part number:
R7440A-9L
R7440B-10T
These were desined for the 8 i'm told
Rotary Swaps
Sep 21, 2015 04:52 PM
Rupanrx
Sep 4, 2015 06:44 AM
Jazzmeson
Aug 6, 2015 04:34 PM
N0P1st0ns
Jul 30, 2015 09:45 AM
