3SIXTY Signal Processors
Old Jun 20, 2006 | 06:07 PM
WikkedOne's Avatar
Deals on wheels
Hey guys.. you know I just did my big install.. and of course as soon as you do something you hear about what you "should" have done.. well I was told about this --
Rockford Fosgate 3SIXTY.1
or 3SIXTY.2
compared together here
they are kinda expensive (400 - 700) but what they do is completly level the input from your head unit and then gives you a electronic crossover and equalizer that you can set via a bluetooth enabled PDA from your drivers seat!
I'm really thinking about getting one of these because I HATE going back to the trunk to change a setting and then going up to listen and then back to the trunk...
also i think that since it does a complete level and then lets you set your own eq your going to get a MUCH better signal going to your amps...
I'm really thinking about doing this.. what do you guys think?
Old Jun 1, 2007 | 03:03 PM
kimota's Avatar
Hi WikkedOne
I just picked up 3sixty.2 and plan on installing it in a RX8 with the Bose system.
Do you have Bose system and if so did you tap before or after the factory amp? If not where you would you recommend I tap for the 3sixty.2 using the Bose system.
Old Jun 1, 2007 | 08:02 PM
WikkedOne's Avatar
Deals on wheels
Congrats on the 362! It's an amazing little piece of hardware
i do not have the bose -- But i think the GENERAL consensus is after the amp.. search around for that - people argue for both.
Old Jun 1, 2007 | 08:18 PM
kimota's Avatar
Thanks man, I'll search around for that got, I've got a CarPC installed cant wait to use it with the 3Sixty.
yurcivicsux
192
Sep 12, 2017 10:54 PM
