subs sound like they are dying...
Old Jun 18, 2006 | 10:29 PM
LiL BenNy's Avatar
Bubblicious? DEF.
recently my subs are not hitting half as hard as they use to... i have a crappy *** battery that ive had to jump a few times... could this be the problem? im looking into a yellow top anyone know the part number?
setup
jl 500.1 amp
2 jl 10w6v2
2 farad power acustik cap
Old Jun 19, 2006 | 11:11 AM
TheBri's Avatar
Spastic Monkey
That could be a number of things.
* Check your ground with a digital multimeter to insure that you've in fact got a good ground.
* Are you positive that you're not just used to the overwheming amounts of bass that you have?
* Did your gain get adjusted somehow on your amp?
* I'd check into your battery problem.
Old Jun 19, 2006 | 12:24 PM
WikkedOne's Avatar
Deals on wheels
I assume you've tapped into both of your rears for in input.. make sure one of your channels for you inputs hasn't come disconnected. or an RCA is loose or maybe a connection somewhere is shorted together (either where you tapped the rears at the line leveler or the speaker connection to the amp)
A yellow top battery is a DEFINATE good idea.. crappy sub or not. Autozone can get you one the next day they cost about 135 all you have to do is go in there and tell them what car you have.
I wouldn't "blame" the battery unless you are getting a noticable power loss throughout the whole car
As Bri said it could also be your power or ground connection. Could be coming loose in a connection to the cap or amp or battery.. double check EVERYTHING from front to back make sure EVERY connection is tight and shorted out
happy hunting and good luck finding the problem and make sure you post it so everyone will know what to look for.
Old Jun 19, 2006 | 09:29 PM
LiL BenNy's Avatar
Bubblicious? DEF.
yep a noticable LONGGG crank when powering the car is one of the main reasons i believe it sucks.
Old Jun 19, 2006 | 10:28 PM
WikkedOne's Avatar
Deals on wheels
In that case then definatly go get another battery whether thats what's causing the subs to suck or not... and then if they still don't work check all your connections like i said
92trbolzr
May 18, 2025 09:04 AM
theblinkof
Oct 4, 2023 05:24 PM
Digitz0070
55
Jul 25, 2017 08:40 PM
Racingjunkie
Sep 29, 2015 05:05 PM
Learners_Permit
Sep 27, 2015 07:38 PM
