Help...hood Refuses To Open
Old Jun 17, 2006 | 05:34 PM
misterwilson007's Avatar
ROTARY POWERED CYBORG
Exclamation Help...hood Refuses To Open
Does anyone have any ideas on how to go about opening a hood that's stuck? I've searched on the web and tried most of the common fixes, but to no avail.
The tension in the cable has loosened. You can hear the latch mechanism working, but it doesn't pop open. I've tried going in from under the front of the car and I've tried pulling the cable with some needle nose pliers....still no fix.
Any ideas? Does the service manual address this problem? Car is out of warranty, so I'm trying to avoid the stealship!
Thanks...
Old Jun 17, 2006 | 07:23 PM
no one has any advice?
Old Jun 17, 2006 | 07:47 PM
blakew15's Avatar
blakew15
I would say the plyers but that already didnt work :/
i have never encountered this problem so im not much help..sorry
Old Jun 17, 2006 | 07:50 PM
DOMINION's Avatar
I don't buy Kool-Aid
Dude I just went out side to see what your talking about and my hood is bent! WTF!? Dam Mazda service guys bent my hood!
Humm out of warranty you say? I would just call them (Your Dealer) and ask how they would do it. Tellem your like stranded
Old Jun 17, 2006 | 08:20 PM
NgoRX8's Avatar
... ouch.
Old Jun 17, 2006 | 10:24 PM
Gomez's Avatar
Shifty Bastard.
Try this one.....
Get a mate to press down firmly (not too firmly!!) on the hood in the area of the latch while you operate the release....
Good luck. The only other alternative is to come up from underneath, removing bits that are in the way.
Old Jun 17, 2006 | 10:46 PM
Originally Posted by Gomez
Try this one.....
Thanks for the advice...I've tried both of those approaches, but no luck. A friend who does body work is going to look at things tomorrow a.m. I'll keep you guys posted on the outcome.
Old Jun 18, 2006 | 08:01 AM
rxeightr's Avatar
M0D Squad -charter member
Hoping the cable is still attached to the latch, I would attempt taking the hood release apart from under the dash, then grabbing it with a pair of pliers.
Old Jun 18, 2006 | 08:54 AM
Problem solved...some how the cable managed to come out of the latch mechanism under the hood. We were able to get a wrench on the 2 bolts that hold the latch on the hood by gently prying the hood open. After those bolts were out the hood came right up! Only took about 15 min.
Old Jun 18, 2006 | 09:07 AM
rxeightr's Avatar
Awesome news.
Does it look like the cable will just need to be re-tightened to the mechanism?
Old Jun 18, 2006 | 09:12 AM
Originally Posted by rxeightr
Awesome news.
wasn't needed...the plastic piece near the end of the cable under the hood was out of the groove that it normally sat in. After we repositioned it everything worked fine!
Initally, I was worred that we were going to have to drill a circular hole above the latch b/c everything else we tried failed to work...that would've been a real bummer.
Old Jun 18, 2006 | 09:39 PM
Gomez's Avatar
Shifty Bastard.
Good result!! (fix info filed away @ back of skull and hopefully never needed.....)
cliffkemp
Dec 24, 2024 10:48 AM
Danield97
Sep 30, 2015 05:59 PM
GK1707
Sep 27, 2015 07:33 PM
