Does the car lock on you...
Old May 16, 2006 | 10:45 PM
NgoRX8's Avatar
Does the car lock on you when it is running?
My senario:
In the garage, I started my car and closed the door. A minute later, I return and try to open the door but it won't budge. Seemed like it was locked. I had to run into my house and get the other set. I had to open the door by putting the key into the keyhole on the driver door. I never thought i'd need that keyhole...
Old May 16, 2006 | 10:48 PM
Read the manual. It's suppose to do that if you punch the correct buttons.
My buttons got pushed when I keep my keys in my pockect so mine doesn't do it any more.
Old May 16, 2006 | 10:50 PM
Student Driver
Did you buy your car new?
If the previous owner had a security or auto-start system installed, it might be causing your
doors to lock.
I don't know of ANY of the OEM RX-8's doing this....
EBF
Old May 16, 2006 | 10:53 PM
NgoRX8's Avatar
i do read the manual... but read what i said, i had already started the car. the remote deactivates when the key is in the ignition.
yes my car is new, i just found it weird because it has never happened before. it has only happened this one time.
Old May 16, 2006 | 11:01 PM
lure3o1's Avatar
mine never has. only locked when its off
Old May 16, 2006 | 11:05 PM
tiggerlee's Avatar
May Cause Anal Leakage
Odd, I was under the impression that the doors wouldn't lock if the key is in the ignition. And no I haven't read the entire manual.
Did you try it a second time, to see if it happens again? Or maybe try the passenger door instead of the drivers?
Old May 16, 2006 | 11:08 PM
NgoRX8's Avatar
yea, i never thought the car would respond to the keyfob with the key in the ignition.
i haven't been able to repeat it, and i kinda don't want to because i don't have my other set right now. lol.
it was either a once in a life time thing or i just suck at opening doors.
Old May 16, 2006 | 11:15 PM
tiggerlee's Avatar
You seem like your pretty mechanically inclined, I doubt it was you. Probably just a fluke. And if it does ever happen again you can bet it'll be when you don't have your extra set available.
Old May 16, 2006 | 11:19 PM
King_RX8's Avatar
yes, i have the same problem before. Ask your mazda dealer to oil the mechanics of the locks.
Old May 16, 2006 | 11:30 PM
aggietiff28's Avatar
Mean Green Keeny Machine
Doors will lock with the keys in the ignition. I have stopped at lights in the shady areas of town and locked my doors many times while sitting at the stoplight. Although, they are not supposed to lock on their own when the keys are in the ignition.
Prolly a fluke or you hit the button without realizing it. Keep us updated if it happens again.
Old May 16, 2006 | 11:36 PM
tiggerlee's Avatar
^Gotcha! I don;t think I made my point very clear in that post anyway. No biggie.
BTW, Wasn't it BunnyGirl who said her doors wouldn't lock while the second remote was in the car with the new '06 remotes? Seems to me I recall her saying she was trying to lock the car and it wouldn't. Then she realized the second remote was in the car. She took it out and the doors finally locked. Did I read that somewhere or have I had a few too many already tonight?
Old May 16, 2006 | 11:47 PM
NgoRX8's Avatar
King, did you have continuous problem with your doors before taking it to the dealer? because it was only one time for me.
Old May 17, 2006 | 12:55 AM
BunnyGirl's Avatar
Yeah. I couldn't get the car to lock from the outside with the transmitter key while the other transmitter key was still in the car. I haven't tried it since the day I first got the car, but it was pretty strange and it took me awhile to figure out why I couldn't get the car to lock. It worked fine after I removed the second transmitter.
Old May 17, 2006 | 11:25 AM
if the door was ajar and you hit the lock button before starting and then closed the door when you got out- that might cause them to delay lock. ill try it later- with the window down so i can reacjh thru for the keys
Old May 17, 2006 | 12:29 PM
NgoRX8's Avatar
lol... confusing... tell me how it goes
Old May 17, 2006 | 01:06 PM
Raptor75's Avatar
I have a similar but different problem. I open my doors with the fob and hear the locks open. I don't open the doors right away but instead use the fob to open the truck. By the time I store things and go back to the door it has locked it self. This has happened several times.
Old May 17, 2006 | 01:07 PM
cjkim's Avatar
^noob
how's that a problem again?
Old May 17, 2006 | 02:34 PM
Glyphon's Avatar
脾臓が痛みました
page 3-4 of your manual.
Old May 17, 2006 | 03:50 PM
Raptor75's Avatar
Thanks, never noticed that.
Old May 17, 2006 | 04:04 PM
dupa12345's Avatar
i may buy the delay story .. but nothing else here about locking .. i always lock my car before closing the trunk as im getting stuff out of it .. then when i shut the trunk i hear locks click and see blinkers flash once
Crazy.8
Apr 18, 2017 03:17 PM
RXeckless
Aug 16, 2015 12:52 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
Jmanie9515
Jul 20, 2015 07:29 PM
AussieGray
Jul 16, 2015 03:58 AM
