Rearview mirror doesn't darken
Old Aug 16, 2003 | 01:17 PM
Jamie's Avatar
Question Rearview mirror doesn't darken
My rear wing is blocking the light that is sensed by the rearview mirror. On the highway, with cars in different lanes, it's not a problem. But when there is a vehicle directly behind me, the rear wing casts a shadow on the sensor of the Homelink mirror, so the mirror doesn't darken. Anyone else experience this? Solutions?
Old Aug 20, 2003 | 03:53 PM
RossComer's Avatar
I run into this same exact problem. I have the mirror pushed up as high as it will go (so it doesn't obstruct my view).
I don't understand why a sensor is used instead of just relying on whether your lights are on.
I don't have a good solution...
rossc
Old Aug 20, 2003 | 09:25 PM
Sputnik's Avatar
Originally posted by RossComer
...I don't understand why a sensor is used instead of just relying on whether your lights are on...
The sensor is used so that it will dim the mirror when headlights are right behind you, and brighten it when noone is behind you so that you can see to the rear in the dark (especially when you are going in reverse).
---jps
Old Aug 21, 2003 | 03:30 AM
TerenceT's Avatar
make sure your front sensor is not block either, which is shouldn't but do check
Jst4fun
Apr 17, 2021 07:43 AM
vapor2
Jul 9, 2016 07:35 AM
nferguson88
Oct 6, 2015 12:45 PM
Luke.s
Sep 30, 2015 05:57 PM
