ShockSensor Problem?
Old Aug 15, 2003 | 10:13 AM
ShawnC's Avatar
After installing the shock sensor(which works fine), I'm hearing this clicking noise coming from the rear door on the drivers side. I hear it when the alarm is set off. And it also clicks when shutting the driver door. Is it a relay or something? Has anyone heard this that has installed the shock sensor?
Old Aug 15, 2003 | 12:32 PM
ShawnC's Avatar
ShockSensor
Ok I've figured a little out. When i shut the door it vibrates the shock sensor which in turn makes that clicking noise. Its throught the car. Its almost like the door solenoid is clicking everytime the shock sensor is triggered. I turned down the sesativity and it stop but thats not good because it wont work that way. Any suggestions.
Old Aug 15, 2003 | 12:51 PM
Superfan's Avatar
Member
Nothing to do with yours but when I was installing mine I had a sudden dyslexia attack. The last wire that you're supposed to splice into is black/blue.. I spliced into blue/black and I couldn't figure out why it wasn't working for 30 minutes. Then I realized that I'm a moron. Now I just have to find another one of those parasite clips so I can hook up the last connection (I don't want to reuse the one I put in).
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
