Suspension Question
Old May 8, 2006 | 07:01 PM
hemmingway_bg's Avatar
Suspension Question
I just had koni sport shocks & H Tech springs installed. My car is now raked. I have four fingers clearance in the rear and one tight finger in the front. I have stock wheels and tires on car. My guess something done on the front to cause this but I do not know.
Old May 8, 2006 | 07:06 PM
tiggerlee's Avatar
May Cause Anal Leakage
I'd be taking it back and get it checked out just to be sure. Not sure what the numbers are on the H-Techs but I recently had Koni and S-Techs installed and the drop is perfect IMO.
Old May 8, 2006 | 07:41 PM
They are nice but do not know why rear end is up in the air. I am hoping someone hear has seen this. I bet your S Tech has more clearance in front than my H Tech springs. I wanted S Tech but chickened out and went with H Tech. I believe my set up will be very good.
Old May 8, 2006 | 07:46 PM
tiggerlee's Avatar
I've got some updated pics in my sig after the install if you'd like to compare them.
Edit: Actually there's a link in that thread to my install pics....sorry.
Old May 8, 2006 | 07:50 PM
tiggerlee's Avatar
Here's what Omicron had to say about the two springs. Still haven't found any pics yet but still looking.
Old May 8, 2006 | 09:48 PM
Winning 8's Avatar
Hot Pit
did you put the rear spring to the front and the front to the rear??
Old May 8, 2006 | 10:03 PM
I did not install myself. I asked that question though. I was told that you can not screw it up but something is wrong. That is as good of a guess as any. I would think if they could be switched I would get an inch more in front and take away an inch in the rear. I will make some calls in the morning.
Old May 8, 2006 | 11:34 PM
staticlag's Avatar
The Professor
That sounds like the problem.
Old May 11, 2006 | 10:01 PM
Springs were reversed. It is easy to do.
Old May 12, 2006 | 01:16 AM
That's what I'm thinking.
BUT you don't measure the height that way.
One way:
Go from center of axel to wheel well.
Other way and prefered method:
Measure height from groond to bottom of chassis. Ground must be flat or use a flat car lift.
If the car height is equal using method 2, but still has a noticable gap between tire and well it's the result from the design of the car from the factory to make it look like that.
Check a stock RX8.
Brokegang
Jan 3, 2016 12:45 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
Sakebomb Garage
Sakebomb Garage
Sep 6, 2015 03:29 PM
