Warm Up?
Old Aug 13, 2003 | 10:44 PM
RX-Nut's Avatar
8 the HARD way.
Warm Up?
How do you folks warm up your RX-8. 0 minutes - JUST GO!, 5 minutes, 10 minutes?
I'd like to get a feel on what most rotary owners do..
Old Aug 13, 2003 | 10:58 PM
sferrett's Avatar
Whaaaa?
I just let it idle until the idle smooths out and then off I go. Typically 20 to 30 seconds.
I am wary to not give it too much stick until its warmed up (about 7 minutes) and keep the revs under 5k or something.
This is in line with what's recommended in the manual also.
I used to let my FD warm up for 5 minutes before going anywhere, but I figure if I just drive it gently for the first 5 minutes the you've got pretty much the same difference and you're 5 minutes ahead.
Old Aug 13, 2003 | 11:23 PM
Superfan's Avatar
Member
RX-8: idle for 1 minute and drive gently for 8-10min (to get the engine oil up to temp).
FD RX-7: idle for 5 Minutes and drive gently until engine oil was up to temp (had an aftermarket oil temp gauge).
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
theblinkof
Oct 4, 2023 05:24 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Jb4ker96
Sep 27, 2015 10:06 PM
